Depends on the device. You'll have to read the associated SCPI programming guide to find out.In some cases there are SCPI commands to read back the entire configuration, in other cases there might not be, and you'd have to read back each setting one at a time.https://www.batronix.com/pdf/Rigol/DP800_ProgrammingGuide_EN.pdf
Thanks for your quick reply, I have a DP800 series PSU and have looked through the programming manual before and have not found a command for full configuration output. Can you point me to the SCPI command?
