I am sharing some programs I wrote for RS 232 serial decode and ARB signal generation.
These programs are written In Labview 7.0, and will likely work with later versions as well.
They are for the Rigol DS1000Z-S series scopes and the Lecroy 900 series. There is also output to the DG1000Z ARB generator, supporting large (MB) waveforms. Ultra Sigma needs to be installed for the Rigol instruments.
I have been using the Beiming F82357 USB to 488 adapter (V1.11 firmware) with the LeCroy.
The source code can easily be modified for other instruments.
Install the Lecroy drivers first, or delete the sections of the programs that use them if only using the Rigol scope.
I wrote these for my own use as I needed the PWM demod and RS232 decode functions. Please continue to share modified versions derived from this work.
https://www.dropbox.com/s/obozvpohqvsmvr0/Cocconi%20scope%20programs.zipAlan Cocconi
