Author Topic: TG6000 Tracking Generator  (Read 2007 times)
Offline Electro FanTopic starter
« Last Edit: April 27, 2015, 04:47:05 am by Electro Fan »
Offline Hugoneus
    • The Signal Path Video Blog
Re: TG6000 Tracking Generator
« Reply #1 on: April 27, 2015, 04:56:06 am »
Interesting. I would like to see phase noise plots.
Although the answers to the last FAQ is correct, the language is sometimes a little unprofessional.
The output power is 0dBm, which is not a lot.
Offline cyr
« Reply #2 on: April 27, 2015, 06:20:30 am »
This device seems quite similar to what I made, a 10MHz reference feeds a PLL synthesizer chip to generate the signal at IF of the analyzer, which is then mixed up or down with the LO signal from the SA to produce the output.  To switch bands you have to switch the RF and IF ports on the mixer, which is why they have an external jumper connection on the front panel.
It will probably have a lot of spurious outputs, not very flat, and not very good SWR. I'm sure it works, not sure it's worth 700$
