Author Topic: wich oscilloscope is better  (Read 2735 times)
Offline ُSTP.AsghariTopic starter
  • Country: ir
« on: November 28, 2022, 06:17:23 am »
Hi everyone
I want to buy an oscilloscope. I have two models in mind. One is the FNIRSI 1014D model and the other is the HANTEK-DSO-2C10 model. Which one do you think is better? Is the first model a good model and is it worth buying?
The specifications of these two oscilloscopes are explained in the following links:
https://www.tme.eu/en/details/dso2c10/digital-oscilloscopes/hantek/
https://www.amazon.com/FNIRSI-1014D-Dual-Channel-Oscilloscope-Generator-Bandwidth/dp/B097T5NRTZ
Offline pcprogrammer
Re: wich oscilloscope is better
« Reply #1 on: November 28, 2022, 06:24:31 am »
Of the two you mention the Hantek is the better one, and it is not telling lies about what it can do.
The FNIRSI 1014D is only 200MSa/s per channel and the bandwidth is <30MHz instead of the advertised 100MHz.
There are several threads about these scopes here on the forum.
https://www.eevblog.com/forum/testgear/new-bench-scope-fnirsi-1014d-7-1gsas/
https://www.eevblog.com/forum/testgear/new-hantek-dso2x1x-models/
Use the search function to find more.
Offline Fungus
« Reply #2 on: November 28, 2022, 11:53:22 am »
It's also twice the price, so...  :-//
It's also scarily close to a Rigol DS1202Z-E, which is a much better oscilloscope.
https://www.amazon.com/stores/page/6AADF13C-8199-4DD1-B005-EF61540C3457
« Last Edit: November 28, 2022, 12:15:24 pm by Fungus »
« Reply #3 on: November 28, 2022, 12:06:28 pm »
Not when I bought them  :-DD
For me they are both hobby projects. Got better ones for the real work.  8)
