Author Topic: Wierd looking Shunt....  (Read 3565 times)
Offline Fungus
Re: Wierd looking Shunt....
« Reply #25 on: December 27, 2022, 12:30:08 pm »
It doesn't take much imagination to visualize the value changing each time it got warm enough to soften or melt the solder.
If you're getting your shunt over 250 degrees Celsius then maybe you're Doing It Wrong,
« Reply #26 on: December 27, 2022, 10:11:51 pm »
Or you're testing the limits of the component...   :-DD
Offline iet
  • Country: cz
« Reply #27 on: December 27, 2022, 11:01:50 pm »
The Shunt had big balls of solder and deep grooves, solder splatter, fingerprint on the inside of the display.
I have seen such shunts in cheap Chinese multimeters.
Offline Wrenches of Death
« Reply #28 on: December 28, 2022, 12:18:35 am »
That's a pretty high temperature. I use only REAL solder with a melting point of about 360 degrees fahrenheit. I think it's 180 degrees on the "C word" scale, which I don't use.
If it doesn't have lead in it, then it's not REAL solder and it's not on my bench.
LEAD FOREVER! Resist government tyranny!
WoD
Offline groovesonshuntTopic starter
« Reply #29 on: January 05, 2023, 02:43:25 am »
I got my eye on a Brymen BM789 instead... :-DMM
Offline BillyO
« Reply #30 on: January 05, 2023, 08:22:27 pm »
