try to use a simple resistor as a load, and see if it behaves ok. You can cut it off some junk pcb.
Try to characterize it under ohms law: I = V/R.
See if at some voltage level, your supply starts failing. If not, get some ceramic resistors with a high wattage, and repeat. If all is ok, then your first load is probably a short, or very low resistance.
