Author Topic: Would this bother you? Rigol 1054Z quality issue  (Read 2451 times)
Offline Fungus
Re: Would this bother you? Rigol 1054Z quality issue
« Reply #25 on: May 31, 2020, 12:35:22 pm »
That black case looks cheap AF, also ugly and hard to read.   :palm:
Horrible idea.  KEYSIGHT, did you hear?
It's not black, it's a "dark theme"...  very fashionable! :-+
« Last Edit: May 31, 2020, 12:37:01 pm by Fungus »
Offline Gandalf_Sr
« Reply #26 on: May 31, 2020, 01:12:34 pm »
Now I look at it, my DS1054Z has a similar mark but I bought it as an open box item so I make some allowance for that plus it's not very noticeable.
If at first you don't succeed, get a bigger hammer
Offline blueskull
  • Country: cn
  • Power Electronics Guy
« Reply #27 on: May 31, 2020, 01:47:44 pm »
Yeah that black Keysight does look cheap but perhaps that's just a marketing trick?
No. My MSOX6004A came with cracked and broken plastic shrouds on logic probe fly wires. Plastic injection molding is a tricky business, especially when you do that with extremely thin or extremely large surfaces.
Offline blueskull
  • Country: cn
« Reply #28 on: May 31, 2020, 01:49:49 pm »
Dark theme, just about to be the new universal aesthetic standard.
Unless you are racist.
Online RoGeorge
« Reply #29 on: May 31, 2020, 02:52:44 pm »
That's a plastic case, not a theme, and its color is black, not dark.  Dark is not a color.
Unless brainwashed.
Offline Fungus
« Reply #30 on: May 31, 2020, 03:04:29 pm »
Dark is not a color. Unless brainwashed.
Designers have to follow fashion.
My theory is:
a) Photoshop is grey because they want the UI to "vanish" and not make an image on the retina.
b) Designers are used to using Photoshop and find anything else garish.
c) Designers believe everybody else sees the world in their colors.
d) Our user interfaces are vanishing and failing to make any image on the retina.
e) GOTO a
I've been in professional color studios and they paint the walls grey for the reasons given in (a). I wonder if the people who work there paint their homes grey?
« Last Edit: May 31, 2020, 03:08:53 pm by Fungus »
Offline noreply
« Reply #31 on: May 31, 2020, 03:55:18 pm »
Some information that might be useful when you want to 'fix' non uniform looking plastic mouldings as in your case.
I use a silicon based liquid called ARMOUR ALL
Get a small dab of it (spray it onto a cotton bud) and touch up the discoloured part of the plastic - just on the edge moving it into the 'good' part of the plastic. See if it improves the damaged area and if it blends into the remaining plastic moulding.
What you are doing with ARMOUR ALL is applying a thin layer of silicon (can be thicker by applying more) over the plastic and this will act as a 'micro filler' in effect diffusing the visible imperfection and blending it with the rest of the plastic.
If it works - enough to hide the imperfections - then apply more to cover the complete area as well as the rest of the moulding around the section in question. Once fully dry - you can 'buff' it with microfiber cloth.
You never know - this might 'fix' the imperfection.
But to your original question - I would try to exchange for new device - it should have not passed QA - especially if it’s on front of scope in predominate area.
Good Luck  ;)
Online Mr. Scram
  • Display aficionado
« Reply #32 on: June 02, 2020, 06:55:32 pm »
The black case is a matter of taste. The sink marks are veritable manufacturing defects. Better control of your process eliminates them.
Online Mr. Scram
« Reply #33 on: June 02, 2020, 06:58:16 pm »
Good Luck  ;)
I'd recommend against using silicone on plastics. In the car world they used to put it in "plastic restorers" but those gained a horrible reputation. The plastics get a nasty cheap shine and once on you'll never get it off again. It'll just spread further and further. Car parts treated with the stuff are considered ruined by many.
Offline noreply
« Reply #34 on: June 03, 2020, 12:09:53 pm »
Good Luck  ;)
Totally agree.
BUT
Not recommending to 'coat' the entire plastic case.
I found good mileage - in applying a very fine (diluted dab) of silicon with a small cotton bud to the worst area - it has an effect of acting like a micro-filler to remove the apparent discolouration which is most likely 'rough' surface patch from the injection moulding process.
In several cases (no pun intended) I managed to hide / eliminate some surface blemishes by using this method.
It’s never a substitute for a new - not faulty device casing - but if you are 'stuck' it worth a try  :-\ - however DO NOT coat the entire case with the silicon for the reasons outlined.
Offline retro_gamer
« Reply #35 on: June 07, 2020, 12:36:33 am »
Hey everyone.  So it looks like Tequipment just refunded me instead of sending out a replacement unit.
Before I buy another Rigol 1054z, is there any other scope I should be looking at?  $500 is probably the most I'd like to spend.
Thanks!
Online TK
« Reply #36 on: June 07, 2020, 02:25:02 am »
Testequipment has the GW Instek GDS1054B on sale for $310 and you can apply the eevblog discount code and get another 6% off
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #37 on: June 07, 2020, 05:02:05 am »
Hey everyone, I recently purchased my first scope and I noticed some strange marks in the plastic.  It kinda looks like someone wiped it with acetone or something.  It's much easier to see it in real life than in the photos.
The pictures look imperfect molding of Jetting and Weld Lines. Typically happens of having not optimal temperature control during the molding.
The Rigol probably do not make the plastic cases, so the company who supplies the molding case did not reject the imperfect molding and Rigol did not check to molding before assembling them.
Most of the time, asking the replacement would come with better moldings.
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #38 on: June 07, 2020, 06:14:03 am »
These models come up in the forum often in this price range?
2ch
RIGOL    DS1202Z-E
SIGLENT SDS1202X-E
4ch
RIGOL     DS1054Z
SIGLENT  SDS1104X-E
GWinstek GDS-1054B
Offline Fungus
« Reply #39 on: June 07, 2020, 06:26:45 am »
2ch
RIGOL    DS1202Z-E
SIGLENT SDS1202X-E
4ch
RIGOL     DS1054Z
SIGLENT  SDS1104X-E
GWinstek GDS-1054B
Yes?
Offline tautech
« Reply #40 on: June 07, 2020, 07:43:26 am »
2ch
RIGOL    DS1202Z-E
SIGLENT SDS1202X-E
4ch
RIGOL     DS1054Z
SIGLENT  SDS1104X-E
GWinstek GDS-1054B
Lots, and the datasheets of each speak for themselves.
Avid Rabid Hobbyist
Offline tooki
« Reply #41 on: June 07, 2020, 05:37:33 pm »
I like black test gear, as I really dislike beige. But you are right that that scope looks cheap, but IMHO just because it doesn’t look like high quality, regardless of color. (Black is FAR less forgiving of surface defects than light colors.)
Random factoid: really good looking black plastic is so hard to get right that a significant share of black plastic electronics are actually painted. (As are, of course, any matte finishes.)
Offline Gandalf_Sr
« Reply #42 on: June 08, 2020, 10:36:54 pm »
I think the black gear looks cool on my workbench but it's way more difficult to read the printed markings on the black gear.
Offline cliffyk
    • PaladinMicro
« Reply #43 on: June 11, 2020, 12:50:06 am »
Hurried production, removed from the mold too soon, too hot--very common on cheap imported crap, I would expect better from Rigol
TEquipment can be a real PITA, A company I worked for bought most everything from them and had numerous issues; don't know why they continued to buy from them. We once waited 8 weeks for them to ship a couple of Lecroy WJ354s that were supposedly "in stock", they had our UPS account # and when they did finally ship them they used overnight delivery, to the tune of $500+ ! Bunch of A-Holes...
-cliff knight-
paladinmicro.com
Offline tooki
« Reply #44 on: June 16, 2020, 07:06:39 pm »
Doesn’t that ultimately depend on the font design and quality of the printing? (Among other things.)
Offline Fungus
« Reply #45 on: June 16, 2020, 07:22:51 pm »
The same designers never had problems putting legible text on white test gear.  :-//
Offline Johnboy
« Reply #46 on: June 17, 2020, 07:15:48 pm »
Here too. A slight imperfection in form of a horizontal stripe above the top four buttons at the right, only visible when looking at an angle.
Same here.
I would not be surprised to learn that this cosmetic flaw is present to some degree on all of these units. However, if I hadn't read this thread, I would likely never have noticed it.
Online NoisyBoy
« Reply #47 on: June 17, 2020, 07:51:23 pm »
You are probably right, as others on this thread had pointed out similar blemish with their Rigol scopes.  I think that could be the reason why they chose to refund the purchase instead of sending out another unit.
But I do think it's a reasonable expectation for a new scope to be blemish free.
Online TK
« Reply #48 on: June 17, 2020, 08:03:37 pm »
Same here.
Even on the MSO50K and the Siglent SDS2K+ scopes
Offline Turrican3
  • Playing is believing
    • Gamers4um
« Reply #49 on: June 25, 2020, 07:50:05 am »
For the record, the exact same kind of (minor, personally speaking, if only because I would likely had never noticed without this thread) aesthetic flaw is present on my brand new Rigol 1054Z.
