Author Topic: Wrong AC Reading on UNI-T UT61B  (Read 1042 times)
Offline YovanTopic starter
  • Country: mu
« on: September 13, 2023, 12:39:23 pm »
Hi all, I am experiencing a wrong reading for all AC voltages, it seems that the read voltage is 1/2 that what it should be . I guess that it is using only one cycle of the AC voltage . Does anyone know which component can cause this  issue ?
Offline GigaJoe
Re: Wrong AC Reading on UNI-T UT61B
« Reply #1 on: September 13, 2023, 01:14:07 pm »
its a one chip does everything kind of device. if it not a protection diodes on input you can look at ... then chip ...
avoid a mistake to measure anything inside by the same unit ( as itself) it may die
  • Country: mu
« Reply #2 on: September 14, 2023, 12:47:05 pm »
GigaJoe,
Do you have any idea which protection diode ?
