I just got a LEM HEME PR 1001 clamp current probe.
Basic specs : 200A / 1000A ranges , scaling of 1mV / A on both.
Other meters in the same series (PR2000) have 10mV/A scaling for the lower range, so I was hoping to change the gain of mine to match that - I'm after the increased resolution of course, this could only at best keep the same accuracy but possibly deteriorate it.
"why didn't I get the PR200 instead" : this one was affordable.
Notes on the overlay and schematics :
[see proper schem in next post]
- part numbering is entirely arbitrary of course
- P1 and P2 blue 0603 are 0-ohm jumpers (R101, R102 in schem)
- currently (!), it draws 14.5mA from the 9V battery. Looks like 5mA for the 78L05's quiescent current, 3.5mA for the LED, 2mA for the voltage divider driving Q1. I'm tempted to swap in an ultrabright LED, and an LDO with the proper caps although this may require calibration. [EDIT : Done. Replaced regulator with LP2950A , new total current draw is ~ 8.2mA. Calibration was indeed required since Vcc changed from 5.11V to 4.99V]
- That thing around IC3, TL061. It seems to say "relaxation oscillator", but: [ ignore the following; see next post]
A) it's not feeding anything except the LED ? For a moment I thought "chopper amp" but no.
B) if it's just driving an LED, why do this ?
C) it ain't oscillating. I'm willing to suspect a bad opamp or bad cap C9 though :
IN+ 4.38V
IN- 3.78V
OUT 4.13V
Why isn't IN- almost identical to OUT ? They're JFET inputs, I_bias should only be around 200pA. And the datasheet says "Common-Mode Input Voltage Range Includes VCC+" , as well as "Latch-Up-Free Operation" so I can't explain this behaviour.
Adjustments:
-VR1: zero adjust. Accessible from front panel
-VR2: no idea. hall effect balance ?
-VR3: low range gain
-VR4: high range gain
-VR5: goes with that TL061-based mystery ?
As far as gain is concerned, it would seem simply a matter of swapping out VR3. I'm not seeing exactly how the math works out for this kind of balanced output stage - any clarifications on this are welcome.
[EDIT : 2020/12/12, updated current draw post-mod]
