Hi all,
I picked up one of these during my last visit to Shenzhen, same store as I purchased my Rigol scope and also have purchased equipment on previous visits so are fairly trustworthy in terms of quality and brands which is why they are my goto place for test equipment when I'm on a buying spree in SZ
I've downloaded the english manual and appears that Menu is considerably different to the Manual. i.e. <Shift> 0 takes me to the menu but only has 3 things to select 1) System Set, 2) List Set , 3) Auto Test Set and then Menu Exit. There is no Config menu and I can't get into calibration mode as described in another threads on this forum.
I'm trying to get the software working with it to record some battery discharge tests which first alerted me to the fact that I couldn't get into the config menu to set baud etc
Firmware on boot up is showing V2.4.
Stephen...
