You will need a crystal. Those adapters are for some quad flat package type. Is that the package you're using? Whilst the programmer only refers to the DIP version, I'm sure the QFP version will program just fine with the right connections.
Presumably the included 4 wires in the first adapter are for the "blue" ISP pins. You'll still need power, ground and the crystal though.
It's all pretty clear in the diagram included with the software. It's basically impossible to help you when you drip feed info about what you have and what you're trying to do.
Which adapter do you have? The second one is quite clear and all the connections match the software diagram perfectly. Is it specifically for the part you are using?
Or do you have nothing? Do you have a board designed? Why can't you program it on the target board and why are you programming it before soldering it?
The ISP programming method is for atmega324p.
Not long ago, a my multifunction tester called tc1 was measuring the capacitor and unfortunately the I/O part was short.
The replacement of the MCU is essential to fix the broken tester.
I don't have any adapter yet. I'm considering purchasing which one suits me. However, there are some questions.
Does the first 4 pin specific adapter doesn't need VCC and GND connection? Are the remaining pins on the X48 programmer dummy?
The second universal adapter does not seem to be a problem.
My plan was to finish the programming first and then solder it on the pcb.
But according to you, can I understand that it is possible to program it after soldering the pcb?
