Another question (except waveform refresh rate) is: Voltcraft's scope has "800x480" pixel diisplay, while Siglent has "only" 480x234 pix. for the same 7" size of display!? I suspect, Voltcraft just cheating (like some el-chipo UNI-T's) compressing 2x2 pixels into one pixel so it turns out the same thing!? But, maybe I'm wrong?
as Tekway started with the production there was no such (chinese) DSO, i mean none with such high resolution.
As a reaction UNI-T decied to "design" similar gear, but of course they did nothing except this 2x2 trick, that was of course crap.
Today, as far i know, UNI-T fixed this crap in their latest models and implemented properly resolution vs pixel per datapoint.
Anyway, regards the resolution. Siglent is using 480x234. For waveview area (rest is menu etc.) there are 8 DIV,
each DIV is 25pix high, each pixel represent one LSB. There are of course 2.24 DIV reamining (as these DSO using
10.24DIV for 8bit resolution), they are there to not allow waveform clipping on top and bottom side of waveform.
Tekway (so as well Hantek/Voltcraft) is using 800x480. For wavevie area there are 8DIV, each DIV is 50pix high,
each
two vertical pixel represents one LSB. But this is not 2x1 nor 2x2, when in RUN mode the DPO-like
shading and persistency are using half LSB as well. Looking on DC line you will see therefore two vertical dots per
one LSB, but when looking on "noisy data" you will see hald LSB as well.
Hameg is using very similar technique, however they used nice trick to make the "two dot vertical" thiner,
the top line is simply bit darker so human eye see it thiner as it is. I've requested this to be added on Tekway fw,
but well, we will see if this can be implemented (as it need some extra resources).
Agilent and Rigol (on DS2k) they using as well two pixel per LSB (however they using as well 1/2 LSB on their
nice intensity grading, so the waveform looks more detailed).
On the other side Tektronix is using on DPO2k the 480x234 resolution, like Siglent.
In principle there is no physical difference between 800x480 and 480x234, both display areas are
using the same physical space, so the resulting line is exact that thin/thick (depending on manufacturer,
model type, sample rate, depth, DSO technology, etc) as on the other.
So the only benefit of these 2 vertical pixels per LSB is the fact that they can be used for high res,
grading/shading, persistency, etc.
And, yes, Hantek/Volcraft has Linux on it, that's the best thing on this scope by my opinion
nope, Tekway is the best
the others are only "clones" (it is not that Hantek is only producing them, they as well designed extras/addons,
Tekway is only the IP owner on the DSO platform, so nevermind).
