Author Topic: (solved) yes yet another hand held DMM thread. what one is better?  (Read 8869 times)
Offline whitevamp
ok I am in need of a new DMM and cant decide what one to get, they all seam not to live up to there safety rating.
But that ok it will live on my bench. and i will use my fluke 8502A ( the ohms card gave out and need I need to fix it.  |O ) for the dc and ac measurements, i need it for Resistance, diode, Continuity. once in while i probably would use it to check mains .. like maby once a year.
so the choices are.
UNI-T UT136Bhttp://www.uni-trend.com/productsdetail.aspx?ProductsID=118&ProductsCateId=219&CateId=219
Mastech MS8268http://www.p-mastech.com/product/detail/464
Extech MN36 http://www.extech.com/instruments/product.asp?catid=49&prodid=298
or squeeze blood out of the proverbial turnip and get  BK Precision 2407A http://www.bkprecision.com/products/multimeters/2407A-mini-pro-auto-ranging-digital-multimeter.html<-- the absolute most i could spend. this one is 35.00
or if there's any other ones that any one would recommend over these ones. max is the 35.00 us. but would prefer to stay at 25 or less.
« Last Edit: October 07, 2016, 06:34:28 pm by whitevamp »
Offline nctnico
Re: yes yet another hand held DMM thread. what one is better?
« Reply #1 on: May 25, 2016, 05:46:08 pm »
IMHO you shouldn't go for a cheap meter if you want to use it for measuring mains!
Offline Wytnucls
« Reply #2 on: May 25, 2016, 05:51:53 pm »
While none of them are particularly exciting, my choice would be the Extech MN36.
Offline whitevamp
« Reply #3 on: May 25, 2016, 05:59:37 pm »
yeah I know i have already had one let go of the magic smoke from checking mains.
but I only have 35 at the max i can spend.  :'(
Offline nctnico
« Reply #4 on: May 25, 2016, 07:29:51 pm »
How about trying to get a used Fluke, Agilent or Tektonix DMM? It will probably have some scuff marks but as long as the casing is intact that shouldn't be a problem.
Offline whitevamp
« Reply #5 on: May 25, 2016, 08:44:23 pm »
have thought about this, but all the ones on ebay that i have bid on i get out bid in the last 1 min of auction.
and the ones i have seen with buy it now are doa, etc, or way more then what i can afford.
« Reply #6 on: May 25, 2016, 08:51:23 pm »
Other than the good advice from Wytnucls who prepared https://www.eevblog.com/forum/testgear/multimeter-spreadsheet/
You could look at Joes thread where he looks at many low priced DMM's and a Fluke 101 might be a good choice for you.  :-\
https://www.eevblog.com/forum/testgear/hear-kitty-kitty-kitty-nope-not-that-kind-of-cat/
I know it's a big thread but well worth some study if you have some time.
Avid Rabid Hobbyist
Offline bitwelder
« Reply #7 on: May 26, 2016, 05:10:50 am »
Can you explain what's this need to *yearly* check the mains?
It doesn't seem you want to monitor mains anomalies (as it would need a dedicated instrument permanently connected to the mains).
Offline julian1
  • http://blog.julian1.io
« Reply #8 on: May 26, 2016, 07:49:46 am »
I have an "inexpensive", made in China, Fluke 15B+ .
After opening it up, it was reassuring to see it using the same make and spec Bussman HRC fuses as the Fluke 87V.
I would recommend the meter, but the fuses alone probably cost $25.
Offline joeqsmith
« Reply #9 on: May 26, 2016, 11:49:02 am »
Looks like about an $80 meter on eBay.
No need to measure current?  Save up another $15 and get the Fluke 101.  :-+  About $50 with shipping.  May be cheaper now.
What brand and model?  What were you doing at the time?
How electrically robust is your meter?? https://www.youtube.com/channel/UCsK99WXk9VhcghnAauTBsbg
Offline TheRadioGeek
    • YouTube Channel
« Reply #10 on: May 26, 2016, 02:35:27 pm »
I have a Sinometer VC97 that I got from Amazon for $36.00. I like it  a lot and I think it's a good meter for around the house and the workbench.
I did a you tube review of it if you want to see it.
Good luck.
Theradiogeek
Offline whitevamp
« Reply #11 on: May 26, 2016, 04:16:09 pm »
if i need to check them IE: change a plugin out, or run a new line. not a typical thing i would do.
Offline whitevamp
« Reply #12 on: May 26, 2016, 04:22:09 pm »
[/quote]
lol umm this was about 20+ yrs ago and it is umm i think an off branded elenco. ( i still use it but not for mains. ) it lifted up the copper trace off the pcb.
and if i remember right i was checking a 110 line.
Offline whitevamp
« Reply #13 on: May 26, 2016, 04:55:13 pm »
thank you all for the input on this question i had.
I have decided to try and save up some $$$ and get like a fluke 118+ or keep an eye out on ebay, for a handheld or a bench meter. ( might take me 4 months, or more. ) and live with the out of tolerance meter that i have been using. ( yes the one that magic smoke escaped from. ) ~10% out.
Offline kasone
« Reply #14 on: May 26, 2016, 06:49:35 pm »
I was going to buy a Fluke 101, but I found a new in the package Fluke 110 on the online auction site. I was the only bidder and paid $34.00 plus shipping. The differences over the Fluke 101 that I have noticed are: 1. Has a bar graph, 2. has max and min function, 3. Does not have frequency.
There are presently a Fluke 110 and a 110Plus on the online auction site with a starting bid of 99 cents.
I am happy with my purchase.
The following users thanked this post: whitevamp
Offline Fungus
« Reply #15 on: May 26, 2016, 08:25:32 pm »
If you don't need current then the absolute safest meter (by a huge margin) is the Fluke 101. You can get them for about $42, shipping included.
Or....if it's really just once a year then get something cheap and take your chances. Triple check it's in the AC mode. Don't hold the meter in your hand, hold just the probes.
(hold both probes in the same hand if possible.
Remember to never do it alone (so the other person can call an ambulance).
Wear safety goggles, big gloves, rubber boots, a thick woolen coat... put a mattress on the floor behind you. Remember to record it all on youtube so we can laugh.
Offline joeqsmith
« Reply #16 on: May 27, 2016, 12:56:25 am »
Looks like they discontinued the 110.    Actually every Fluke I tested including the 101, 107, 115 and 17B+ did very well except for the 87V which fell way short.   To date, the meter I pushed the hardest was 5Ky's Fluke 107.   I am not sure if the the 101 could handle that same level or not.   Certainly in the sub $50 range, I have yet to see a meter as robust as the 101!
Offline mos6502
  • Country: aq
« Reply #20 on: May 27, 2016, 02:02:16 pm »
Oh, Fluke77 - unfused 10A terminal?  :-[
(sorry, If I missed something)
That's got to be some kind of rare special version. I have a 77 and it's definitely fused. Looks like this:
for(;;);
Offline kasone
« Reply #21 on: May 27, 2016, 04:09:19 pm »
Here is a Fluke 112   http://www.ebay.com/itm/152104475441?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The 112 has the current measurement capability.
Same seller also has a Fluke 110. Both presently have a 99 cent bid on them.
One other feature of my 110, It is a true RMS meter.
Offline mzacharias
« Reply #22 on: May 27, 2016, 07:30:47 pm »
The earliest  version of the 77 was unfused on the 10A input.
Somewhere while still in "Series I" production, the fuse and holder were added.
I wince a bit whenever I see an unfused on on eBay.
Offline Fungus
« Reply #23 on: May 27, 2016, 07:45:24 pm »
I really love that Fluke 37.
Wonder how ridiculous the postage to Spain is...
Edit: The seller replied "$56"  :(
For $35 I'd buy it right now. For $35+$56 plus a probable $30 hit on import duty ... I dunno.
Edit 2: There's a guy on eBay France selling them for 20 Euros + 15 for postage!
Will I, won't I...?
« Last Edit: May 27, 2016, 09:25:54 pm by Fungus »
Offline Fungus
« Reply #24 on: May 28, 2016, 10:19:49 am »
Edit: There's a guy on eBay France selling them for 20 Euros + 15 for postage!
Will I, won't I...?
I did.  :-DMM
I was reading the manuals and it looks like it's a Fluke 27 in a benchtop format, complete with carrying handle and compartment for storing the leads, etc.
3200 count, 0.1% accuracy, 1000 hour battery life, chunky... What's not to like for 35 bucks? Can't wait to take it along to Arduino club.
(let's hope the fuses are intact...  :-\ )
Offline mos6502
  • Country: aq
« Reply #25 on: May 28, 2016, 03:17:48 pm »
Oh well. You have to remember those are from a time when doctors recommended to pick up smoking to help with digestion.
for(;;);
Offline whitevamp
« Reply #26 on: May 28, 2016, 05:31:47 pm »
whelp i just ordered off that auction site a Klein Tools MM1000 for 18.39 buy it now price.  :-DMM
lets hope it works good.
Offline retiredcaps
« Reply #27 on: May 28, 2016, 06:57:22 pm »
The MM1000 is similar to the UEI in Dave's $100 shootout.
It will be interesting to see how these two auctions end for the Amprobe meters. 1 cent bid with no minimum/reserve and 50 minutes left to go as of this post.
http://www.ebay.com/sch/edcarrawayjr/m.html
« Last Edit: May 28, 2016, 07:02:55 pm by retiredcaps »
Offline whitevamp
« Reply #28 on: May 28, 2016, 07:09:13 pm »
good too know
yeah it will be.
Offline whitevamp
« Reply #29 on: May 28, 2016, 07:52:49 pm »
good too know
yeah it will be.
Amprobe - Compact Digital Multimeter 15XP-B
i bit the bullet and bought it for 5.50 :-DMM
« Last Edit: May 28, 2016, 08:00:55 pm by whitevamp »
Offline retiredcaps
« Reply #30 on: May 28, 2016, 09:14:47 pm »
I got its predecessor called Meterman 15XP for 99 cents about 5 years ago off ebay.
Offline joeqsmith
« Reply #31 on: May 29, 2016, 12:51:49 am »
$5.50 US, that's cheap! Met your $35 max!
Offline whitevamp
« Reply #32 on: May 29, 2016, 01:13:50 am »
whelp i went over  by 14 i had just bought 2 used mm1000 for 18.39 ea + free S&H and that new 15xp-b for 5.50 + 6.50 S&H
Offline karoru
« Reply #33 on: May 29, 2016, 02:24:38 am »
Most electricians I know (mind that mean age is 50) use cheapest clamp meter they could find at local hardware store and by some miracle are still alive and doing their job just fine. And before advent of DMMs they used lightbulb with two wires and they also weren't being electrocuted on a daily basis. Heck, I couldn't even kill a 2.5$ "QC PASSED" brand DMM with an insulation tester that goes to 1.5 kV, only injury was my hand being sore after rotating that stupid crank for too long. I don't know where does the assumption that every cheap meter blows after getting close to mains socket come from. Well, ohms range circuit on a cheapie won't probably be happy after getting 230 V to the test leads, but analog meters also die pretty horribly after trying to pull such a stunt and nobody considers them "unsafe".
