So all these responses got me curious. I went back and ran more test with a probe set to 10:1 ( was my worse case ).
Probe not connected to anything - about 50mV of noise
Probe and probe ground connected to scope ground - about 50mV of noise ( very faint and fuzzy compared to above)
Probe tip connected to probe ground ( no scope ground ) - no visible noise
Probe tip connected to scope ground, probe ground unterminated - about 200 mV. I think my earlier measurement must not have had a good ground.
I also ran an FFT with CF at 102MHz and could see some peaks from the local stations. None are very strong, my bench is down in my basement cornered by two concrete walls and dirt. Above me is a bunch of sheet metal duct work.
In the end, I'm not worried about anything I see. A good refresher on probing though.
Joel
