Author Topic: Yokogawa 701922 differential probe - bipolar power supply?  (Read 2204 times)
Offline 0xdeadbeefTopic starter
« on: July 08, 2015, 09:04:11 pm »
More or less a theoretical question, but anyway: I could get a Yokogawa 701922 for a good price which seems to be a rebranded Testec TT-SI 200, but there's one catch (in addition to the very limited +/-20V differential voltage range), namely that the Yokogawa version has some proprietary Lemo connector instead of the default Testec one. In the 701922's manual the connector's pinout is shown, but it's +/-12V while the Testec TT-SI 200 has a single supply from 3.3V to 16V (but the official voltages are either 6V or 9V). I would assume that only +12V and GND are actually used and that I could use a 9V battery as well, but I'm hesitant to buy a probe with a very limited voltage range and the risk of having to tinker and mess around with a +/-12V supply.
So does anybody know for sure if the Yokogawa 701922 can supplied by a single positive voltage (like 5V or 9V) just as the Testec TT-SI 200?
Offline aronake
  • Country: hk
Re: Yokogawa 701922 differential probe - bipolar power supply?
« Reply #1 on: May 09, 2024, 02:35:16 am »
Bringing back this extremely old thread.
Anybody who have the answer to this?
I am also curious about how sensitive these Yokogawa differential probes are to input voltage. It seems the Testec version is run on 6V to 9V. Yokogawa on 12V, or maybe +/- 12V. So seems rather wide. But the Yokogawa may have been modified.
Offline aronake
  • Country: hk
« Reply #2 on: June 06, 2024, 03:35:05 pm »
If anybody is interested in knowing, the Yokogawa 701922  require both the positive and the negative 12V to work properly. I added LEMO connectors on a tektronix 1103 tekprobe power supply, so now I can use both old active tektronix probes and yokogawa probes. I feed the yokogawaprobes with 15V +/- but they seems to be ok with that.
