@DDunfield: Thanks for the advice.
I've given this a first try on a Metrix MX53 (BK Precision 5360).
For now using Windows 7 and SX-DMM V2.9 with a USB BT dongle (IS1601N-G / IS1002N-307G chips), I'd like to
upgrade to windows XP but stuck for now due to this problem:
https://www.eevblog.com/forum/testgear/sx-dmm-seeking-old-versions-of-the-bk-precision-metrix-software/On the DMM side before messing with the DMM's PCB itself I've followed the IR route for now: A phototransistor and IR LED are fed to a JDY-31 Bluetooth module.
The module has previously been renamed and set to 2400bps via USB to UART.
No problem getting the DMM to throw the data out to Realterm over BT using the DMM's "Print" key. BT connection stays active, module's status LED is constantly ON.
Now, problems start when trying to use the dedicated SX-DMM software, no way to get a connection.
The software normally makes 3 attempts to request DMM status by sending 35+CR, the same attempts over BT seem to fail because the BT link goes back to standby (status LED blinks) the SX-DMM does not keep the BT serial port active as Realterm does. Each time status request is transmitted the BT attempts to go active again but is too slow for the DMM to respond in time.
Attached screen captures of normal and failing status requests.
Any way I could trick this connection to remain active, I've been through windows but haven't stumbled on it yet. Maybe a registry entry for the BT serial port?
