I didn't bother with epoxy, I just went ahead and used superglue on the cracked piece, the crack didn't extend the full length of the piece, it was just in the skinnier half. And I added some grease to those parts too. I also added a washer, to hold the inner spring in place, I don't think I lost one, and the spring easily extends where it's not supposed to, all the way through the big outer "gear".
But see the actual timebase knob, it bolts to a metal press-fit bushing (I guess that's the name), and the bushing was tight on the hollow shaft (until I had to remove it, since the plastic piece is now glued to the other end of the shaft).
The very end of the shaft was knurled, and just past that, the shaft gets skinnier for a few mm or 1/4", but the excess metal was squeezed out into little fins, parallel to the shaft. This bushing, which is basically a pipe with threads on the outside of 1 end, has 4 slits cut cut on the other end, parallel to it's length, and those fins on the shaft fit into the slits.
But using pilers and a hammer/anvil, I can't get the bushing to hold tight on the shaft. It can slide about 1mm before the knurling stops it falling off.
I really don't want to be hitting this hard, since it's all back together, and superglue is on the other end of the shaft, already a bad choose.
OH NO, now I've cracked that bushing just squeezing it with pilers on the shaft, 1 of the end quarters split off. I'll have to goto a local machine shop and get them to make me one.
I'm wondering if the bushing was meant to be squeezed way more over the knurled end, and only part of it would extend to the fin section.
But I had pushed it all the way down to the shoulder of the shaft, and just tried to squeeze the bushing tight.
