Author Topic: Zoyi ZT-XT1 Transistor tester / multimeter  (Read 3124 times)
Offline uncle_sem
Re: Zoyi ZT-XT1 Transistor tester / multimeter
« Reply #25 on: May 15, 2026, 12:33:34 pm »
Have you performed a calibration after the FW update?
hmmmm.... interesting idea, I'll try it later...
Offline kae64
  • Country: ua
« Reply #26 on: May 15, 2026, 03:54:50 pm »
The service sent me the firmware - XT1_ZOYI_108_113, but my transistor tester doesn't initialize; it shows version 0,0,0. On XT1_ZOYI_110_116, everything seems to work except for the automatic DC voltage measurement mode.
Offline kae64
  • Country: ua
« Reply #27 on: May 16, 2026, 08:01:51 pm »
Of the downloaded firmware, could you tell me if the XT1_ZOYI_108_113 firmware was fully installed? My multimeter installs version 1.0.8, but the transistor tester doesn't, showing version 0.0.0. The XT1_ZOYI_110_116 firmware is fully installed, but the DC voltage auto measurement mode behaves oddly: up to 10 volts, it shows erroneous values, but above that, it measures correctly. When changing registers, it measures correctly.
