Author Topic: (Very) cheap DIY battery for Flir Exx and other - 7.28€ - 7.2Ah :)  (Read 1613 times)
Offline tisher
We need:
1. 1s2p battery 3.6V 7.2Ah: https://nexun.pl/en_US/index?maxsote_zapisany_koszyk=124324 - 5.33€
2. Kapton tape or other insulating tape
3. NTC 10K: https://nexun.pl/en_US/p/-Temperature-sensor-NTC10K/764 - 1.12€
4. PCB protection board for 1s battery: https://www.ebay.com/itm/1S-3-7V-7-5A-Li-ion-Lithium-1X-Battery-Protection-Board-3-MOS-Tube-BMS-PCB-DIY/312610298048 - 1€
5. Connector (5 pair) https://www.aliexpress.com/item/1005001402738137.html - 3,64€ - 1 pair - 0.78€
6. Wire
7. Hot glue gun  :-DD (sorry guys, i don't have 3d printer but if you have, please make better battery case for this project)
=========== TOTAL: 7.28€
8. 1s 4.2 cheap battery charger - 2€
Step by step  :popcorn:
External battery charger
« Last Edit: November 25, 2020, 07:31:22 am by tisher »
The following users thanked this post: Fraser, frenky, _Wim_, Ismsanmar
Offline Fraser
Re: (Very) cheap DIY battery for Flir Exx and other - 7.28€ - 7.2Ah :)
« Reply #1 on: November 24, 2020, 12:00:24 am »
Tisher,
Thanks for this post and fir identifying the connector used to mate with the Exx series camera. People have asked where to buy these previously and now they will know  :-+
A 3D printed casing does make life easier when it comes to mounting the connector on the top. Even just a top cap that holds the connector securely to the battery would work well. You solution using hot melt glue works though and that is what matters  :-+ Another option might be to make a simple Plasticene (children’s modelling clay) mould for a top cap that will hold the contacts and pour either 2 part Epoxy glue of plastic embedding resin into it to make a moulded part. An original battery can be used to make the basis of mould by pushing it into the modelling clay (with the contact holes covered) Hours of fun to be had  ;D
« Last Edit: November 24, 2020, 12:24:04 am by Fraser »
Offline Uho
  • Country: ua
« Reply #2 on: February 04, 2021, 01:16:36 pm »
Thanks for the idea. I made a charging cup for Flir E 60 batteries
