Author Topic: 12 Days of Thermal Riddles  (Read 11269 times)
Offline eliocor
    • rhodiatoce
Re: 12 Days of Thermal Riddles
« Reply #25 on: December 14, 2017, 11:40:45 pm »
Fruit (apple?)
Offline capt bullshot
« Reply #26 on: December 15, 2017, 07:00:56 am »
The magic 8 ball
Offline frenky
  • Country: si
    • Frenki.net
« Reply #27 on: December 15, 2017, 07:46:14 am »
Christmas ball ornament
Offline Rerouter
« Reply #28 on: December 15, 2017, 08:02:06 am »
I'm going to take the obvious one and say an orange, or similar member of the citrus family,
Offline VipitisTopic starter
  • aspiring thermal photography enthusiast
« Reply #29 on: December 16, 2017, 12:07:58 am »
so, I am late a little.
number 4 was a globe, a light up one... but it was really reflective - you can actually see my head(the lower dark spot).
« Reply #30 on: December 16, 2017, 12:21:11 am »
I am late on this one as well. I had some fun with it... and I will try to find some subjects that are less round...
5/13
« Last Edit: December 16, 2017, 12:48:27 am by Vipitis »
Offline Raj
  • Country: in
  • Self taught, experimenter, noob(ish)
« Reply #31 on: December 16, 2017, 08:31:00 am »
A part of a car dashboard
« Reply #32 on: December 16, 2017, 10:28:28 am »
Insulated piping and a pump (part of the central heating boiler)
« Reply #33 on: December 16, 2017, 11:36:35 pm »
I am getting late again. I had some issues transferring files from my phone to my computer and therefore don't have the nice pictures yet.
number 5 was my bicycle bell it is shiny metal and therefore is reflecting the night sky - the brighter spot is a reflection of myself. I used a custom color palette made with palette generator look at the attached screenshot.
« Last Edit: December 16, 2017, 11:50:14 pm by Vipitis »
« Reply #34 on: December 16, 2017, 11:48:31 pm »
6/12 by Ultrapurple
btw post #100
« Reply #35 on: December 17, 2017, 12:45:58 am »
Too easy. A "Quality Street" tin with some of the sweets.
BTW, to bring it back to electronics momentarily, those make great screening cans for breadboarded circuits. A moment's work to punch a hole for a BNC or whatever.
« Reply #36 on: December 17, 2017, 01:08:43 am »
Here is a backup 6/12 because the lower resolution makes it harder
« Last Edit: December 17, 2017, 01:53:22 am by Vipitis »
« Reply #37 on: December 17, 2017, 11:10:05 pm »
There was no participation yesterday. But someone got it correct on Instagram. It is a 2by2 extention cord.
« Reply #38 on: December 17, 2017, 11:16:23 pm »
7/12
I believe this is a good one
Offline onesixright
« Reply #39 on: December 17, 2017, 11:25:58 pm »
Any change of posting the original (non thermal) image if you have one?
Very funny how the imagination takes over  :-DD
Rorschach test?   ;)
« Reply #40 on: December 18, 2017, 12:22:51 am »
I can take a visual image of the same subject. This image isn't really taken as a thermal capture, more as a art piece to get a nice effect.
I don't usually drop hints but for this low resolution images, it's a trick to scale them down so your brain puts it together better and maybe see a pattern in the noise.
It does make a difference to me on a lot of my images and it's an effect I haven't read a paper about yet.
Offline Spirit532
  • Country: by
    • My website
« Reply #41 on: December 18, 2017, 02:50:38 am »
I've noticed that effect too, and it extends past still images.
If I capture something with my high-speed camera at 160x80 resolution and 60 000 fps and blow it up onto a 28" 4K display, it's practically impossible to determine what is in the image(even when moving!), but as soon as it's squeezed down into a tiny thumbnail size, it's much easier to understand.
Now to write a paper and get published in a scientific journal.
Offline frenky
  • Country: si
    • Frenki.net
« Reply #42 on: December 18, 2017, 07:27:43 am »
To me it looks something between roller coaster metal construction and mushrooms.  ;D
« Reply #43 on: December 18, 2017, 09:40:23 am »
Looks like a car in the background and something else in the foreground.
« Reply #44 on: December 18, 2017, 11:11:37 pm »
It's inside my computer. I got sleeved tubes for water cooling. And you can see some wires in the background.
I will put a visual image, just need to remind me
« Reply #45 on: December 18, 2017, 11:15:02 pm »
8/12
Offline The Soulman
  • The sky is the limit!
« Reply #46 on: December 18, 2017, 11:37:27 pm »
Ow no, peeing in the snow?  :-//
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #47 on: December 19, 2017, 12:47:27 am »
That's some warm snow, if so...
Seven Transistor Labs, LLC
« Reply #48 on: December 19, 2017, 10:11:14 am »
A fence in the foreground, some houses in the background, in between - a cow peeing upwards to the sky  :)
Offline vinicius.jlantunes
  • Country: br
« Reply #49 on: December 19, 2017, 11:00:58 am »
Maybe it's a bit cold to be someone peeing? But it does look like that for sure!  :-DD
It's very much like it's some liquid being poured, but looking closer I don't think it is the case. There seems to be like a tube coming out with hot liquid (the "pee stream") and a couple coming in from the lower part.
I will guess it's a circuit board with some liquid cooling system for whatever chip is under the bright spot. The other small warm spots around are not pee drops but other small chips that also get a bit warm.
