A NUC describes the per pixel corrections that are applied to make all of the pixels in the array appear uniform. For them to be uniform, they should all provide the same output value for the same scene.
An FFC will create an offset map per pixel that makes each pixel have the same value, when looking at a Flat target.
A two point NUC will also create a gain map per pixel to compensate for the different Gain that each pixel has, so that when looking at scenes with different levels, the pixels will still be uniform. This is typically done by using a “hot” and “cold” target.
Sent from my iPhone using Tapatalk
