Hello, my name is Frank. I have lurked on EEV for a little while but just registered recently. I have a question about what IO module is compatible with a Indigo Omega core. I purchased a Indigo core with the environmental housing which afforded me a nice sturdy enclosure with what looks like a germanium view port and most important of all, a breakout board that has the now obsolete connector made by JAE Electronics, Inc. part no-DA1B018H91 which is referred to as the "camera connector", this is soldered to a small pcb with a standard looking molex connector then passing the signal/power/data along to what looks like a lemo connector on the back of the enclosure. So I have one connector for the camera side, I am still in need of another breakout board to build a cable, or if at all possible find a factory interface cable to connect the camera to the IO module. First I need to make sure the IO module I just bought on ebay will work with the Omega core, I have some pics of the IO module and connector used on the breakout board which is labeled with the correct pin-out for composite video and power as I understand it. I would be grateful for any help with this question, i'm just getting my feet wet with thermal stuff.
