Author Topic: Thermal eye 2620AS not working (solved)  (Read 7197 times)
Offline RO
Re: Thermal eye 2620AS not working (solved)
« Reply #25 on: September 23, 2023, 09:26:09 pm »
I also found a new problem, J1 has 13 pins  :palm:
But it's identical to the one from RTF
http://www.rtftechnologies.org/general/thermal-imager-L3-thermal-eye-2500AS-2620AS.html
with similar pins
(SAM_2033a.jpg)
« Last Edit: September 23, 2023, 09:47:36 pm by RO »
Offline Bill W
    • Fire TICS
« Reply #26 on: September 24, 2023, 03:41:08 pm »
The 2000AS has a 13 pin J1
See http://www.fire-tics.co.uk/project1/index.htm
I have the 13 way pinout there, but no guarantee it is the same as a 2620AS.
Bill
The following users thanked this post: RO
Offline RO
« Reply #27 on: September 24, 2023, 06:23:25 pm »
Oh perfect! Thanks Bill! that's exactly what I needed.
I assumed I had a 2620AS as it looks identical to Andrews camera from RTF Technologies
linked at:
https://www.eevblog.com/forum/thermal-imaging/why-some-thermal-cameras-can-stand-direct-sun-light-while-others-cant/msg2367696/#msg2367696
But no sticker is present on the optical block, and now I think it might be 2000AS, most details are conform your documentation, 13pin J1 and the DSP chips. (same goes for the RTF unit)
