Author Topic: Guide PC210 Review  (Read 45557 times)
Offline markb1980Topic starter
  • Country: cz
Re: Guide PC210 Review
« Reply #75 on: February 10, 2023, 02:23:38 pm »
I have borrowed the PC210 to a friend - if I recall correctly that activates a box-measurement area in 3 sizes.
I do not memorise the differences between FW-versions but as you can't update the firmware anymore yourself that is all you get and you stuck with it! If I recall corretly 1.3.x or 1.4.x is the latest version. So 1.2.2 seems to be an older version.
You need to look at the forum - older versions had issues when using manual level & span!
Best try what happend to images when you activate or deactivate the ROImeaturement.
« Last Edit: February 10, 2023, 02:26:19 pm by markb1980 »
Pentester, Digital forensics examiner, Data recovery technitian, Author for various books
Learn thermal imaging: https://www.amazon.com/dp/B0B5KXF41Q/ | https://www.facebook.com/groups/1816479168568552 | https://thermal-image-samples.com/thermal-pixel-peeping/
Offline sikseb
  • Country: hu
« Reply #76 on: February 10, 2023, 07:49:00 pm »
Thanks. Would anyone know the diff between version and firmware for this pc210 model?
Offline damanloox
  • Country: ie
« Reply #77 on: February 20, 2023, 06:29:44 pm »
Does anybody know if there's any way of capturing "live" view (even with a lag) from the PC210 to mac? I can see "IR video" device when connected to the mac but can't use it ie. can't see it anywhere / in any recording/webcam software...
Offline Matthias
« Reply #78 on: February 21, 2023, 08:59:22 am »
Hey there, I wanted to "drop" the information that the camera stores uncompressed IR pixel data in the jpeg. I was looking into this a bit because I was curious how the software works (... actually, it isn't working so great for me).
So I looked 3 hours into it and came up with a proof of concept of how to get the data out. Unfortunately, it is far from working properly as there seem to be some "mis-decoding"...
If somebody wants to fiddle further:
https://github.com/NerdyProjects/Guide_PC210_ImageExtractor
The following users thanked this post: Hawaka, markb1980
Offline Hamelec
« Reply #79 on: February 24, 2023, 03:58:02 pm »
Received the PC210 today, it is really working great.
But never seen such a useless user manual.. >:(
« Last Edit: February 24, 2023, 04:01:54 pm by Hamelec »
The following users thanked this post: John-O
  • Country: cz
« Reply #80 on: February 24, 2023, 04:11:54 pm »
Chineese manuals look often so.  |O
Offline Hamelec
« Reply #81 on: February 24, 2023, 04:54:05 pm »
« Last Edit: February 25, 2023, 09:09:30 pm by Hamelec »
Offline serenkiy515
  • Country: kz
« Reply #82 on: April 17, 2023, 10:57:39 am »
Hello. I ordered a PC210 for myself. While I'm waiting for the package, I'm reading your forum. Could you please email me the latest firmware. Or give a link? :)
s.gezik@mail.ru
« Last Edit: April 17, 2023, 01:48:17 pm by serenkiy515 »
Offline Hamelec
« Reply #83 on: April 17, 2023, 11:02:09 am »
Firmware update is not recommended due to the risc of loosing the calabration data
Offline serenkiy515
  • Country: kz
« Reply #84 on: April 17, 2023, 01:46:52 pm »
I got a camera today. It immediately became clear that the device overestimates the temperature. So I think I need to try flashing.
Modification: v1.3.6.20220520
firmware; v1.2.2.20211206
  • Country: cz
« Reply #85 on: April 17, 2023, 02:14:46 pm »
What was the emissivity set to and what did you try to measure?
Offline serenkiy515
  • Country: kz
« Reply #86 on: April 17, 2023, 03:46:15 pm »
Your hand. 44 degrees, emissivity = 1
P/S I apologize if I'm not expressing myself correctly. I use a translator.
« Last Edit: April 17, 2023, 04:12:42 pm by serenkiy515 »
  • Country: cz
« Reply #87 on: April 17, 2023, 05:55:51 pm »
I would exchange the unit - a update will not fix the issue for 98% sure. If you are out of the 14 days in which you can return the unit without a reason then you will have issues to reclamate that maybe...
Skin should have some value in the 0.96-0.98 range I belive but that can not cause such issue normally. You can try if E=0.96 will help. The PC210 has anyway some issues with temp. readings according to many users here. I have a decent model but it has some firmware-issues which don't get solved by an update.
The have anyway taken the cetisism and made adjustments for the new PF210 but old PC210 users don't get a firmware-update.
Test also the software - it will not update the temp. readings when you change emissivity or the RAT. So also that is not really working great.
Offline serenkiy515
  • Country: kz
« Reply #88 on: April 18, 2023, 01:46:11 am »
:) There is news. The device spent the night in my room. In the morning I found that the temperature had returned to normal. Maybe when I got it, it was still cold inside. Or raw. He drove in a truck for 7 days at -8 degrees.
And yet the issue with the update remains open. please share the file.
:) Есть новости. Прибор пролежал ночь в моей комнате. На утро я обнаружил что температура пришла в норму. Возможно когда я его получил он еще был холодный внутри. Либо сырой. Он ехал в грузовике 7 дней при -8 градусов.
 И все таки вопрос с обновлением остаётся открытым. поделитесь пожалуйста файлом.
  • Country: cz
« Reply #89 on: April 18, 2023, 07:21:43 am »
To my knowledge noone has the actual file. There is a file around which some users have but it's not the latest one.
Guide request you to send the device in for firmware update.
You can look maybe some of the users here still has a update-file on his PC but as I told you it's not the latest version.
The following users thanked this post: serenkiy515
Offline serenkiy515
  • Country: kz
« Reply #90 on: April 19, 2023, 02:31:22 pm »
Anyway, I want to update. No one but you is talking to me here :'( .
I think I figured out why there are such different readings in temperatures. Firstly, it is inertia. The device is large and closed. Inside it there is a thermocouple which is the reference point of the thermometer. When we go outside with the device from the room, the device relies on room temperature when measuring (does not have time to cool down / heat up), hence the incorrect readings. If the device is on the street for a couple of hours, it will start measuring normally (only on the street), there will be discrepancies with room thermometers in the room again.
I think this is not a revision of :palm: the case or the software.
Who didn't disassemble the device? See if there is a thermocouple or a thermistor inside 8)
Все равно, хочу обновить. Не кто кроме Вас с мной здесь не говорит  :'( .
 Кажется я разобрался почему такие разные показания в температурах. Во первых это инерция. Прибор большой и закрытого типа. Внутри него есть термопара которая является точкой отсчета термометра. Когда мы с прибором выходим на улицу из комнаты, то прибор опирается при измерении на комнатную температуру (не успевает остыть/нагреться), отсюда и неправильные показания. Если прибор полежит на улице пару часов он начнет мерять нормально (только на улице), в комнате снова будут расхождения с комнатными градусниками.
 Я считаю это не доработка  :palm: корпуса или программного обеспечения.
Кто не будь разбирал прибор? Посмотреть есть ли там внутри термопара или терморезистор  8)
Offline Hamelec
« Reply #91 on: April 19, 2023, 03:27:29 pm »
Anyway, you are free to do what you want - also to ask five times more for a firmware.
Some opinions to it are written here:
https://www.eevblog.com/forum/thermal-imaging/guide-pc210-review/msg4818269/#msg4818269
https://www.eevblog.com/forum/thermal-imaging/guide-pc210-review/msg4817654/#msg4817654
and also in other threads here..
good luck.
Offline berke
  • F4WCO
« Reply #92 on: January 09, 2024, 10:11:31 am »
Does anyone know how to get a video feed from this under Linux?  It's UVC class but guvcview for example can't handle it.  (I'd like to avoid messing with the FW if possible.)
Offline marmalade
« Reply #93 on: January 29, 2024, 10:22:26 pm »
I'm confused by the frame rate in the specs. What does 25Hz / 9Hz mean? Why are there two frame rates? Can someone help me?
Online Hawaka
« Reply #94 on: January 30, 2024, 08:22:00 am »
Have a look at this, maybe you’ll find some info on the video stream
https://github.com/Lexy1972/PC210Viewer
The following users thanked this post: berke
Offline berke
  • F4WCO
« Reply #95 on: January 30, 2024, 09:03:08 am »
There really isn't much in the code, it uses OpenCV to capture the images and by the description it just flips/rotates the image.
I'll try capturing with OpenCV.
Offline marmalade
« Reply #96 on: February 02, 2024, 12:48:37 pm »
Costumer service wrote the following:
For frame rate, 9Hz for US market, 25 Hz for other markets.
The following users thanked this post: Hamelec
Offline rogerdammit
« Reply #97 on: February 23, 2024, 10:49:41 pm »
Is it possible to switch country or some other setting to get 25 Hz? Or it is hardware/firmware locked?
Online eTobey
    • Virtual feature script
« Reply #98 on: November 12, 2024, 12:04:39 pm »
Has anyone managed to get this cam working displaying on the PC with a lag that is smaller than 1s?
"Sometimes, after talking with a person, you want to pet a dog, wave at a monkey, and take off your hat to an elephant." (Maxim Gorki)
sincetheSDS800XHDhasatroublesomekeyboardandidontlikedoingunecessaryclicksmylabelsusuallylooklikethistext
