Author Topic: "Black Silicon" based night vision device  (Read 6125 times)
Offline Logan
« on: December 03, 2021, 02:11:20 pm »
Hi guys.
Since my thermal hobby actually began from night vision, I'll post it here. However mods can move this if you feel off-topic.
To avoid advertising, I'll do my best to hide the brand/model. This is a pure technology talk.
I just got a unique night vision device that is not IIT(tube)-based, but based on "black silicon" CMOS.
https://en.wikipedia.org/wiki/Black_silicon
Before this, all so-called "digital night vision" are like jokes after jokes. But just look at the pictures attached, this device is truly amazing. (Pictures are from internet because I haven't got a chance to take decent photos yet, however I can assure you these pictures are from the same model I'm talking about)
It have a sensitivity similar to Gen-2 tube(or ISO 200k), and with color. It will not be damaged by daylight, or have a limited life-time like IITs. And the resolution is 720p, similar to Gen-3.
More surprisingly, its spectrum sensitivity goes all ways into SWIR.  :box:
What more would I ask for a device much less than $1k?
Oh wait, actually I do want one more function: wired video signal output. Because the EVF is not always comfortable to use, and the built-in wireless transfer never work.
One thing I just thought, is they should use a custom CFA, not the conventional bayer filter:
1. CMY color-resist would be a better choice instead of RGB, because they allow 2x light through.
2. The filter block rate should be as low as possible, just enough to let the processing stage to guess the color.
3. There should be half or more pixels just without any colored layer.
4. All color-resist should be transparent to IR.
Since they already go so far to "Black Silicon CMOS", I don't see a reason why not do this to make it better.
Finally, this is not the "X27" scam from the scammy "SPI corp" shit!  :-DD
Thanks for reading.
Online Fraser
Re: "Black Silicon" based night vision device
« Reply #1 on: December 03, 2021, 02:30:37 pm »
The BBC has been using very low light colour cameras for wildlife imaging work recently. I wonder if those cameras are using this technology. It was described as groundbreaking colour imaging technology as it provides good clean images when most colour cameras would not even provide an image, let alone a colour balanced image !
Interesting stuff and no problem detailing it in this part of the forum. Discussions cover IR to LWIR and THz imaging here  :)
Fraser
The following users thanked this post: Logan
Online LaserSteve
« Reply #2 on: December 03, 2021, 03:28:17 pm »
I have a Si*nyx Aur*ra sport.  Favorite toy during power failures, boating, checking on things that go bump in the night, working in the laser lab, etc.   While I feel a black and white version would be awesome, color does add some unique aspects. Near IR sensitivity which I have tested to to 1084 nm is awesome.
Optics are quite decent and well designed.
Questions not requiring an ITT-Excelis grade  NOD test bench will be answered...
One caveat, if I'm going into combat, or playing paintball,  a tube device designed to purpose would still be my preference.  Aur*ra does have a minimal  inverted video mode and a long eye relief for helmet mounting.  That is based purely on the S*ort model.  Not sure about the LE versions as I do not have access to them.
I will not do a tear-down, I love it too much.
Ask away...
Steve
« Last Edit: December 03, 2021, 03:42:43 pm by LaserSteve »
"I've Never Heard of a Nuclear Meltdown Caused by a Buffer Overflow"  filssavi
Offline Logan
« Reply #3 on: December 03, 2021, 04:40:49 pm »
Thank you Fraser, you are very kind.
I think BBC maybe using something like Canon ME20F-SH. That's even more sensitive than my device, but many times the price...
Offline Logan
« Reply #4 on: December 03, 2021, 04:44:19 pm »
Wow you have the same device as me!
I already did a tear down, and broke something(whole thing still working after reparing), but I don't regret it. I believe if I don't see a device inside, it's not mine.
You want some teardown photos?
Online Fraser
« Reply #5 on: December 03, 2021, 06:47:06 pm »
The Canon M20F-SH looks to be an impressive bit of professional camera kit  :-+
https://www.canon.co.uk/for_home/product_finder/camcorders/multi-purpose-cameras/me20f-sh/
Online LaserSteve
« Reply #6 on: December 03, 2021, 10:24:18 pm »
Just want to know if the module in my Sp*rt looks exactly the same as the DEV kit device on their website. As the  DEV Kit has a variety of direct video outputs. I have an idea from looking at the case there are "other" options either planned or discarded. A good question is what is the led or photosensor thing under the viewing screen, inactive on my model.  Is there a slot for a standard GPS module?
Things of beauty:
Very flexible optics.  A rifle scope or camcorder with a good zoom lens can look right into the eye piece, and the adjustable eye relief is very, very, good.  Take note FLIR, they have you beat on that one in the low end.
Common battery, standard camera battery.
Decent battery life.
Color lets you correlate your daytime inherent  knowledge of your area with the night scene.
Color with a little moonlight shows what the backyard Coyotes are doing, much better then gen II / Gen III greyscale (Greenscale>)
Also makes identifying cars much easier. Coyote fur blends in well with my local grass on tube based NODs.
Deals VERY well with bright sources in the field of view.  Not producing serious halos..
Nicely complements my thermal imager.
Well programmed digital zoom code.
Decent weight.
Charges very quickly, keeps a charge. (Take Note FLIR, My Scout has to LIVE on a charger or external USB B pack)
Great dynamic range, much better then my Find-*R-Scope in the laser lab.  Also no chance of indirect viewing if something went wrong.
Reasonably Tough.
Exporting images is very easy.
Even though it is shooting long exposures in deep darkness, algorithm used makes for a nice real time display.
Plenty of video color schemes, great ability to record stills and movies, with playback.
Downsides:
Loud Beepy noises on startup or mode change, . Makes me want to do a speakerectomy.
External function LEDs  give your position away by design in Sp*rt model.  Might just be they want other civilians to know your there.
Would be nice if it fades the display as you move it away, it will "beacon" you if not against your eye.
Would be nice to turn off the data strip at the bottom of the screen.
Rating for the cost: ***** Five Star.. Would definitely buy again.
Steve
« Last Edit: December 03, 2021, 11:28:19 pm by LaserSteve »
Offline zrq
  • Country: cn
« Reply #7 on: December 04, 2021, 01:12:56 pm »
How do these cameras compare to the "scientific grade" CMOS cameras, which seems to be more available? :-//
Offline Logan
« Reply #8 on: December 04, 2021, 05:41:47 pm »
Tear-down photos!
16 photos total.
1/3 post.
Offline Logan
« Reply #9 on: December 04, 2021, 05:44:30 pm »
16 photos total.
2/3 post.
Anyone knows the CPU model shown in "mobo1.png"?
« Last Edit: December 04, 2021, 05:53:27 pm by Logan »
Offline Logan
« Reply #10 on: December 04, 2021, 05:46:03 pm »
16 photos total.
3/3 post(finish).
Offline Logan
« Reply #11 on: December 04, 2021, 06:05:13 pm »
If you can see a way to get video output, please tell me!
The sensor behind the EVF window is not exist.
The GPS BGA place is on the button board, see my photos.
The notice sound can be turned off in settings.
Just put a sticker over the LED...
Turning off the boarder and use it for picture is a good idea, but:
The EVF is 1024x768(4:3), the sensor is 1-inch 1280x1024 (5:4) physically, with 1280x720(16:9) active, this is why they can use a more common 2/3 lens... Edit: You cannot, I tried the 8mm model lens within the same brand and series, dark corner appears. If you can unlock the full resolution, you're a hero.
Since you did a review, here's a simple one for my mind:
Bad:
No wired video (like HDMI) output;
External power don't work without battery inside.
Need improvement:
Have more lens (FOV) options;
Fix the Wifi function or remove it;
Fix a bug that you can't set time over 12:00 in 24-hour mode.
Maybe I ask for too much:
Custom CFA mentioned in OP;
A more "tear-down friendly" construction.
Good: Everything except above!
« Last Edit: February 05, 2022, 03:26:03 pm by Logan »
Offline Logan
« Reply #12 on: December 04, 2021, 06:09:41 pm »
sCMOS is actually much more expensive than this one...
Do you have a approximated ISO number of a normal sCMOS? that would be a good way to compare.
Online LaserSteve
« Reply #13 on: December 04, 2021, 10:01:30 pm »
Wow, Thanks for the teardown.  I'm impressed with how it is built. Clearly not intended for hacking, in fact probably quite secure. Their Intended market outside of the personal sales must be interesting.
Steve
Online LaserSteve
« Reply #14 on: December 04, 2021, 10:11:21 pm »
is the lens a C or CS mount? Is it glued in?
Steve
Offline johnelot
« Reply #15 on: December 05, 2021, 07:53:24 am »
i have the aurora pro and it is c-mount , or at least a c-mount screwed in just fine, the original was glued in by some filled holes around the lens , araldite type stuff but easy to see as its a whiter color
Offline zrq
  • Country: cn
« Reply #16 on: December 05, 2021, 01:53:23 pm »
Check Thorlabs (https://www.thorlabs.com/newgrouppage9.cfm?objectgroup_id=11421) for kinda affordable new ones and Andor for super fancy ones. Andor also offers expensive EMCCD cameras, and I once used one when I was in a cold atom lab.
These scientific cameras hardly give ISO specs but only Peak Quantum Efficiency (how many photons -> electron), Read Noise (how much additional noise when counting the electrons), and dynamic range.
Offline Logan
« Reply #17 on: December 05, 2021, 03:41:10 pm »
I've heard they already have a agreement to supply sensors to US military, I forgot the source...
For the mount, read johnelot's reply, he's right.
Offline Logan
« Reply #18 on: December 05, 2021, 03:48:41 pm »
I also saw an EMCCD camera in a lab, but never had a chance to see how does it look like when looking at a dark environment(instead of through microscopes...)
Yes that's the problem. I really want someone with both sCMOS and a "normal" camera that can set ISO, to compare them. But for years, no one done that yet.
Offline RO
« Reply #19 on: December 07, 2021, 09:40:02 pm »
There is some very interesting lens mod info and telescope builds with the aurora syonix and pro on the astro forum:
https://www.cloudynights.com/topic/681442-sionyx-aurora-for-nv-photography/?hl=%20aurora%20%20lens%20%20mod
And then there is this firearm enthousiast who modded it into some thermal fusion night vision device
(fiber optic periscope type)
https://www.thefirearmblog.com/blog/2020/09/25/friday-night-lights-diy-modified-aurora-digital-thermal-fusion/
[youtube] https://youtu.be/OUq2-VoDCoA [/youtube]
The following users thanked this post: I wanted a rude username, Logan
Offline zrq
  • Country: cn
« Reply #20 on: December 08, 2021, 12:17:58 pm »
Seems they have a paper here: https://www.spiedigitallibrary.org/conference-proceedings-of-spie/11741/117410E/Ultra-low-light-CMOS-image-sensors/10.1117/12.2588472.full?SSO=1
~80% QE and 1.1e readout noise are pretty close, if not better, than the SoTA scientific CMOS. And to me, it looks like there isn't much headroom for further improvement in terms of sensitivity as it will get to shot noise limitation. I would like to get one if it's available in Europe.
Update: with a closer look at the website, I feel it's a bit dodgy as the spec for products is sort of vague, for example, I can not find what's the longest possible integration time. I hope I can find more info about the sensor used.
« Last Edit: December 08, 2021, 02:50:46 pm by zrq »
Offline Logan
« Reply #21 on: December 11, 2021, 02:14:58 pm »
Thank you guys for replying.
There's something strange about this device: The "black silicon" should be several times (10x? I forgot) more sensitive on physical level, but comparing to Sony A7S which is not black silicon, this camera is about the same performance per pixel area (A7S have slightly better low light performance, with its lightly bigger pixel pitch).
I guess it's mainly because Sony have a much better processing algorithm(such as noise reduction), so for this camera, the advantage on hardware level gets buried by the worse processing...
Online LaserSteve
« Reply #22 on: December 12, 2021, 01:32:39 am »
Google Hyper-Had by Sony, "Hole Accumulation Diode"  sensors were from say 9 years ago. I'm sure they improved upon it since then. For something like an SLR they might have used the newer "Super HAD" with lens on pixel technology and textured Silicon. The newer 5 transistor per pixel noise reduction circuit  plus HAD has achieved really phenomenal results.
I used to have a picture shot with a HH sensor of a large conference room shot with scattered light from  candle hid between a filing cabinet and a wall. Let a few long 100 mS exposures build up. Let it sum the exposures in the camera's DSP with whatever Kalman filter they use.  Summed in the camera software, was almost as good as Gen II.  night vision for a still scene if you were willing to set still for 10 seconds or so.
So I have no doubt Sony can push Silicon to its limits.
Steve
« Last Edit: December 12, 2021, 01:51:52 am by LaserSteve »
Offline Ultrapurple
  • Just zis guy, you know?
    • Therm-App Users on Flickr
« Reply #23 on: December 15, 2021, 04:40:11 pm »
I've just acquired a used Sport and can confirm that it's an interesting toy. Sensitivity to red light, in particular, is extremely high. I suspect also to near-IR. When set to 7.5fps and black & white it's possible to see around a room lit by one power-on neon. But those YouTube videos claiming performance equalling or exceeding Gen III are at best somewhat misleading.
I plan to do some tests in due course to try and relate its sensitivity to ISO figures on a 35mm camera. But it'll have to wait until I can get to some open countryside: there's too much local IR floodlighting to do a fair test.
Rubber bands bridge the gap between WD40 and duct tape.
The following users thanked this post: MarcusG, Logan
Offline Logan
« Reply #24 on: December 16, 2021, 11:41:03 am »
Thank you.
If I remember correctly, early HAD series can back to 1980s...
Their modern DSLRs are using CMOS instead of CCD.
Thanks.
