Nice photo, thank you.
I have bumped some of the wires on mine & was able to nudge them back into proper spacing with a scalpel but have not broken any yet. As close as the lid structure is to those wires it's a wonder I haven't done worse.
Without taking a fresh look at mine under the microscope I was thinking that maaaayyyybe it would be possible to straighten yours out and, with a fine wire extension fitted to a soldering iron tip, solder them back together--IF they were merely broken somewhere in the middle. But it looks like some of yours are pulled off of the chip and your 1mm scale is a quick wake-up to the potential fantasy of that notion (0.01" between wires!). Need to get smaller piano wire.
Sometimes you can do things with crude equipment but this probably does need the proper equipment for the job... which I don't have.
