Products => Thermal Imaging => Topic started by: vision on February 27, 2021, 11:40:07 pm
Hello all. I bought a Cadillac "night vision" camera, tested it with a poor quality rca cable. The picture seemed very zoomed in and very grainy. I could hear the chopper wheel hitting something when I powered it up. Figured the wheel film is toast so I pulled it apart to inspect and 3d print the one from this forum to fix the problem. The chopper wheel looked new but I continued to take it apart. Pulled the wheel and found a sensor behind the wheel was loose. Super glued it back down reassembled and now the picture is barely comprehensible. No thermal imagery activity, just b/w static like the old days of trying to watch the late night raunchy cable channels that didnt come in. Did I just break my new camera? I Figured the caps were needing replacing but I dont know what to look for on SMD caps that are blown. Im glad I found this forum.
Oh, camera is the v2 gm thermal camera. I applied 12v to the 2 pin connector that connects to the lens assy, my understanding from the schematic I saw was one side gets voltage and the other is a ground. The other connector was wired to power and rca.
UPDATE: Took it apart and saw the chopper wheel was installed backwards. I now have thermal imagery. However, it looks to be zoomed way in still and the picture is still pretty grainy.
Zoomed way in? Could you post images to show what you are getting? I know most versions are running punched in, only the raytheon reference design is full image view capable afaik.
Re-read some posts on here about the this TI and have some afterthought.
Were these sharp images to begin with? Using a 42 inch tv to test with would show some low quality video on a hdtv so that might answer the grainyness in question. The image being zoomed near infinity is probably the normal focus. I re-read the 3d printed lens holder would allow me to focus, but I would lose any airtightness, right?
Vision, that looks about normal for the Caddy cameras I've seen and tinkered with.
You can focus without losing your water tightness, the screw on the back by the fins is a feed port for the hex drive lens screw, can't remember what size key off the top of my head, but you need kind of a long one to get to the gear drive internally.
Thank you for the information. I was wondering why a pressure cap would be a screw and what it was for. Maybe my picture will look better on a smaller 7" screen.
You wouldnt by any chance know how the front lens cover comes off?
There's a couple of stills and videos of a BST at work on my site, may be a worthwhile comparison:
http://www.fire-tics.co.uk/A2.htm (http://www.fire-tics.co.uk/A2.htm)
http://www.fire-tics.co.uk/A3.htm (http://www.fire-tics.co.uk/A3.htm)
The differences from Cadillac are:
Argus was in fixed gain, then used an iris
Argus was in the 320x240 setup, Cadillac is 320x120.
Not sure if Cadillac was a higher frame rate, so lower integration / higher noise, however the human eye- brain averaging should sort most of that out
Bill
