Author Topic: Can anyone help me identify this camera?  (Read 2982 times)
Online Fraser
Re: Can anyone help me identify this camera?
« Reply #25 on: September 22, 2023, 09:39:46 pm »
Software guide......
Online Fraser
« Reply #26 on: September 22, 2023, 09:40:35 pm »
Laptop configuration guide......
Online Fraser
« Reply #27 on: September 22, 2023, 09:41:18 pm »
Software guide....
Online Fraser
« Reply #28 on: September 22, 2023, 09:42:56 pm »
The software download page that also includes an ONVIF interface.......
https://silentsentinelhelp.helpdocs.com/fixed-modum/modum-software
Fraser
Offline 40xbTopic starter
« Reply #29 on: September 28, 2023, 02:43:11 pm »
I found the Blackbody box in the same room. I cleaned it a bit and it does power up.
I still need to find a power cable for the camera housing. Work has picked up significantly and I haven't had a lot of time to find a power supply cable locally.
I appreciate you and your time Fraser.
Online Fraser
« Reply #30 on: September 28, 2023, 03:20:50 pm »
Good to see that the Blackbody was still around. Be careful if trying to clean the painted emission plate. The surface is easily damaged. I cannot be sure of a safe method of cleaning the emission plate as much depends upon the coating that has been applied and how solvents may affect it. Distilled water is the safest cleaning solution but IPA may be used on some other surfaces. LCD screen cleaner or water based glasses cleaner are also pretty safe cleaning solutions. Always test the cleaning solution with a cotton bud in the corner of the emission plate. If the white cotton bud soaked in the cleaning solution turns black when applied to ten emission plate, the cleaning solution is dissolving the coating !
Fraser
« Last Edit: September 28, 2023, 04:14:44 pm by Fraser »
« Reply #31 on: September 28, 2023, 04:13:52 pm »
I used air then IPA on the body and internally. I only used air on the plate.
