Author Topic: Chinese HT-18 220x160 8 Hz Handheld Thermal Camera  (Read 15617 times)
Offline nidlaX
« on: February 02, 2018, 04:18:05 pm »
https://www.banggood.com/HT-18-220x160-Handheld-Infrared-Thermal-Camera-Thermograph-Camera-Digital-Temperature-Tester-p-1255696.html
Regular pricing looks decent, but no full resolution image samples available, only crappy videos.
Thoughts?
Offline Spirit532
  • Country: by
Re: Chinese HT-18 220x160 8 Hz Handheld Thermal Camera
« Reply #1 on: February 02, 2018, 04:27:06 pm »
That's interesting, I've never seen a 220x160 sensor, the closest that comes to mind is the 206x156 Seek Gen1 sensor, which is fairly unobtainium for a white label manufacturer.
The sample images don't look have thermopile array levels of noise either...
For that price it sure doesn't look like it's going to be an upscaled Lepton 3, the lens doesn't suggest that either.
This is the actual manufacturer of this unit:
https://hytechcn.en.alibaba.com/product/60737113891-800587624/High_resolution_ht_18_thermal_imaging_camera_china_made_ir_camera_heat.html
Could this be a new development?
« Last Edit: February 02, 2018, 04:32:39 pm by Spirit532 »
Offline Cat
« Reply #2 on: February 02, 2018, 07:24:28 pm »
Chinese handheld thermal imagers like the Guide IR510 seem to have their "own" 400×300 sensor, too. A few years ago they used 384×288 sensors from ULIS.
Maybe there is already a chinese fab producing microbolometers?
On the Internet, nobody knows you're a cat.
Offline Fraser
« Reply #3 on: February 02, 2018, 09:51:34 pm »
Interesting. I cannot find any detail on the sensor technology they are using.
The pricing is competitive if the camera performs to specification.
Fraser
Offline Fraser
« Reply #4 on: February 02, 2018, 10:06:59 pm »
Even China sourced Microbolometers are still quite an expensive component, so this new camera seems almost too good to be true....... $400 to $1000 for a microbolometer alone.
https://www.alibaba.com/product-detail/Night-Vision-Thermal-FPA-Uncooled-Microbolometer_60676296305.html?spm=a2700.7724857.main07.1.25e25884X22GEu
The above referenced Chinese Microbolometer looks like a ULIS Clone and production of such an encapsulation is expensive,
We may have to wait and see if anyone does a treardown on one of these cameras to find out its secrets.
Fraser
« Last Edit: February 02, 2018, 10:15:44 pm by Fraser »
Offline Fraser
Offline nidlaX
« Reply #6 on: February 02, 2018, 10:54:09 pm »
Indeed, I'm considering getting one to do a review.
Offline Spirit532
  • Country: by
« Reply #7 on: February 02, 2018, 11:59:12 pm »
I believe that's a sensor manufactured by DALI or one of the other fabs - it's possible to purchase it, if you know where to look, but it's not cheap and it's a bad performer(compensating with pixel count).
I was often quoted ~$400-900 for a 320x240 to 640x480 sensor. Quite a price range, but it's not awful. The support and documentation doesn't exist though, you're supposed to just guess how it works, from what I gathered.
This is entirely new, it seems.
Offline thm_w
« Reply #8 on: February 03, 2018, 11:35:02 am »
http://img.banggood.com/file/products/20180122025645ht-18English.pdf
The manual shows it uses MSX/thermal combined image. But they don't really show any example images, other than some likely photoshopped picture of a car engine.
JPG only capture.
Offline Spirit532
  • Country: by
« Reply #9 on: February 03, 2018, 11:56:21 am »
This datasheet shows an entirely different picture:
Suspiciously similar to the Seek lens....
Offline nidlaX
« Reply #10 on: February 03, 2018, 12:02:55 pm »
I don't get the sense that it uses the visual camera for image enhancement, only that you can also capture visible light images alongside the thermal images.
Offline Spirit532
  • Country: by
« Reply #11 on: February 03, 2018, 12:06:30 pm »
It probably does the boring "image blend" that you see on the $150 and $250 camera models. No edge detection.
Offline amspire
« Reply #12 on: February 03, 2018, 12:07:15 pm »
JPG only capture.
That car engine may just be the startup screen. It seems you have to switch between the camera vision view and the IR view - there does not seem to be any composite mode.
It is a single button press to switch the views, and you could always combine them later in an image editor. That way you can compensate for the positional offset of the two lenses.
Offline Andyelectric2000
  • Banned!
« Reply #13 on: May 08, 2018, 09:24:56 am »
Ich habe mir mal die HT-18 zugelegt die zur zeit den Markt überschwemmt. Ich muss ehrlich sagen sie hat mich überrascht !!
Gestochen scharfes Bild mit sehr guter Trennschärfe und das Rauschverhältnis ist Phänomenal ! Wesentlich besser als bei Flir one oder Seek  Bei der Sensor Einheit scheint es sich um ein Stand alone Modul zu handeln  das über ein dünnes USB Flachbandkabel an ein Board führt das sehr stark an einen gewöhnlichen Tablet PC erinnert.... Da ich das Modul nun gerne an einen PC oder Tablet anschließen würde  bräuchte ich natürlich den Treiber .... Gibt es eine Möglichkeit den aus dem Gerät auszulesen ?
https://imgur.com/uUdakJI
https://imgur.com/IZcmU8f
https://imgur.com/xZzu4p8
https://imgur.com/SLjHwur
https://imgur.com/j7lIpHX
https://imgur.com/UDnNqhQ
https://imgur.com/5X5GdHK
https://imgur.com/Zw95DMr
Beste Grüße !!
Andy
Online Vipitis
  • aspiring thermal photography enthusiast
« Reply #14 on: May 08, 2018, 09:37:46 am »
Hey, could you share some sample images directly from the camera? I would also like to know what price you paid for it + shipping to Europe.
Also resume your postings in English so more people can understand it.
  • Banned!
« Reply #15 on: May 08, 2018, 05:23:27 pm »
Hi, Yes, It makes only single photos and is displayed on the pc only as a memory....
the single images are not high resolution but usable....it is more suitable as a night vision device.....
https://imgur.com/mfxPUwS
https://www.ebay.de/itm/Warmebildkamera-3-2-Portable-Infrarot-Thermometer-IR-Infrarot-Imaging-Gerat-HT18/302691112113?hash=item4679cbd4b1:g:LksAAOSw3qZa6ssG
Best Greetings !!
Andy
  • Banned!
« Reply #16 on: May 08, 2018, 08:47:59 pm »
USB extension in work.....
https://imgur.com/FlrYCI1
  • Banned!
« Reply #17 on: May 14, 2018, 08:04:39 pm »
Hi
USB extension fix and waterproof housing in progress .... ;)
https://imgur.com/mZKIP6D
https://imgur.com/oLrTVLo
https://imgur.com/DBHlEHR
Best Greetings !!
Andy
The following users thanked this post: nidlaX
Offline nidlaX
« Reply #18 on: May 14, 2018, 08:34:34 pm »
Whoa! Nice mod! :-+
The following users thanked this post: Andyelectric2000
  • Banned!
« Reply #19 on: May 15, 2018, 08:21:24 pm »
I completed my waterproof good resolution Thermal outside camera  for 300 bucks....
The window is made of cellophane turns out weather resistant and heat permeable....
https://imgur.com/SU7EIgj
Best Greeting !
Andy
Offline ixfd64
    • Facebook
« Reply #21 on: July 14, 2018, 09:11:37 am »
The 14-year-old in me giggled at the name of the website.
« Last Edit: July 14, 2018, 09:13:26 am by ixfd64 »
Online blueskull
  • Country: cn
  • Power Electronics Guy
« Reply #22 on: July 14, 2018, 09:41:31 am »
Wait until you see pound land and mega flick.
Offline Ben321
« Reply #23 on: July 14, 2018, 12:14:40 pm »
Thoughts?
Best bet is to buy it and check it out, if you have enough money to toss out for the sole purpose of testing equipment.
Offline sdouble
« Reply #24 on: July 16, 2018, 10:24:36 pm »
I bought one and received it.
The resolution seems not as good as expected.
The following users thanked this post: flukevietnam
