Getting the Pak-Tracker to display me something has been unsuccessful.
I searched the Wayback machine for a manual for the EI320 Pak-Tracker user manual but haven't come up with anything, and I tried every button combo I could think of.
Nothing changed on the display, the attached beeper beeps 1x on startup and keeps silent then.
A red led lights up on the Scott Pak-Tracker PCB, but I have no reason to believe it indicates any type of malfunction.
The tracker board pulls about 120 milliamps, which might be a bit low, but I honestly don't know what it should do, and if it might be on standby waiting for a activation signal
The core alone takes 389, and after a software shut down with the Pak-Tracker PCB attached it keeps pulling 60 mA.
The core with unattached tracker shuts down completely. (Core only 0mAmp)
I think I'll leave it at this as the Pak-Tracker functionality is of little interest to me, but obviously any advice and insight is appreciated.
