Author Topic: (Solved) Disassembling a FLIR i series camera - hints please  (Read 5824 times)
Offline FraserTopic starter
« on: February 17, 2017, 04:26:17 pm »
My FLIR i5 MK1 (Blue & Grey) camera has arrived.
I want to disassemble it for some investigation inside. Has anyone already disassembled the case of a MK1 i series camera please. It would be helpful to hear about how it is constructed. I could X-Ray it but I am in the process of rebuilding the two X-Ray controller PC's so not convenient at the moment.
Fraser
« Last Edit: March 16, 2017, 09:42:08 pm by Fraser »
Offline sam1275
Re: Disassembling a FLIR i series camera - hints please
« Reply #1 on: February 18, 2017, 05:25:15 am »
I asked for the same thing before but no reply...
https://www.eevblog.com/forum/thermal-imaging/how-to-tear-down-flir-ix/
« Reply #2 on: February 18, 2017, 09:30:28 am »
Looks like I wil be firing up the X-Ray machine then :)
Fraser
Offline sam1275
« Reply #3 on: February 18, 2017, 11:42:18 am »
Fraser
Waiting for your good news buddy!
Offline sam1275
« Reply #4 on: February 18, 2017, 11:46:21 am »
I just got a good answer in my post  ;D
Offline pimpinge46
« Reply #5 on: March 16, 2017, 01:41:54 pm »
just pulled mine apart. There's two screws under the sticker on the front by the lens. once you remove those two . There's two more screws under the front shutter assembly .  Two more in the handle underneath the battery (ones under the top battery sticker )/
« Reply #6 on: March 16, 2017, 02:52:50 pm »
Pimpinge46,
Many thanks for this information. I was suspicious that there were screws under the label around the lens but was not certain.
I saw an auction for a butchered i7 that supported my thoughts about the front label as it had been trashed,  presumably during a a less than careful disassembly. I attach the auction pictures. Scary case damage ! It was ex construction company that had several i7 cameras. It was probably used for parts to repair others, or just a poorly executed repair attempt after its screen was broken.
I am going to warm the front label with a hair dryer and hope it may be lifted without damage. Much depends upon the adhesive tape FLIR have used.
« Reply #7 on: March 16, 2017, 02:54:21 pm »
Continued horror.....
« Reply #8 on: March 16, 2017, 02:56:28 pm »
Final horror pics......
This camera sold for the equivalent of £75 in the USA. Brave buyer is all I can say !
Fraser
Offline pimpinge46
« Reply #9 on: March 16, 2017, 03:25:09 pm »
ouch!
