Author Topic: DJI Mavic 3 Thermal Lens Swap  (Read 2036 times)
Offline regolithTopic starter
« on: April 12, 2024, 09:13:44 pm »
Hi guys,
I have a DJI Mavic 3T and I want to increase the magnification of the thermal lens, currently it has a FOV of roughly 61 degrees. I would rather that be closer to 15 or even 10 degrees. Can anyone offer any insight into where to find replacement lenses for such a camera?
Offline Chanc3
Re: DJI Mavic 3 Thermal Lens Swap
« Reply #1 on: May 01, 2024, 09:46:57 am »
It uses an iRay/InfiRay core, so you can probably find an alternative lens from them. You won't be able to calibrate the gimbal however and would require balancing.
