Author Topic: Drone mounting?  (Read 1205 times)
Offline KeithLipswichTopic starter
Drone mounting?
« on: March 20, 2023, 04:57:19 pm »
Hypothetically how difficult would it be to mount something like this on a drone?
Online themadhippy
Re: Drone mounting?
« Reply #1 on: March 20, 2023, 05:32:50 pm »
easy
or maybe
biggest issue is finding the right point to mount it without affecting the drones balance
« Last Edit: March 20, 2023, 05:34:30 pm by themadhippy »
The following users thanked this post: karpouzi9
Online ArsenioDev
    • DiscountMissiles: my portfolio and landing page
Re: Drone mounting?
« Reply #2 on: March 20, 2023, 05:40:51 pm »
you forgot hot snot and super glue
Online Fraser
Re: Drone mounting?
« Reply #3 on: March 20, 2023, 06:23:45 pm »
Mounting = Easy
Data handling and communications air to ground = not easy
Re: Drone mounting?
« Reply #4 on: March 20, 2023, 09:09:51 pm »
Thanks, that's the bit I figured was going to be a challenge.
Most existing thermal imaging drone set ups are big expensive and require a license, insurance etc, mounting something like this on say a Mavic mini 2 would have some commercial potential if it could be sneaked inside the 250g limit
Offline aargee
Re: Drone mounting?
« Reply #5 on: March 22, 2023, 03:14:18 am »
It would certainly be interesting for a drone to have a USB-C camera connector and stream whatever it was fed.
Not easy, not hard, just need to be incentivised.
Offline karpouzi9
Re: Drone mounting?
« Reply #6 on: March 22, 2023, 04:26:34 am »
... and a gigantic legal risk for the OE should someone attach "discouraged" peripherals to such a port and do evil.
Re: Drone mounting?
« Reply #7 on: March 22, 2023, 12:42:18 pm »
One of these could be simply strapped on and already has bluetooth comms but at 153g is probably a bit too heavy and bluetooth range may be an issue
Offline gamerpaddy
Re: Drone mounting?
« Reply #8 on: March 24, 2023, 02:35:40 pm »
Pi zero + any phone thermal imager with usb, that usually registers itself as a webcam.
just process the raw / monochrome video in opencv to your liking and output it over the tv header in analog composite / fbas into a fpv / ocusync transmitter.
Offline unseenninja
Re: Drone mounting?
« Reply #9 on: March 24, 2023, 09:39:17 pm »
You really do not need to worry about a drone's balance (if you mean the type driven by multiple horizontal rotors, at least), as the flight controller automatically compensates for imperfect weight distribution, as long as it's not pushed to extremes of course.
Offline n4u
Re: Drone mounting?
« Reply #10 on: March 24, 2023, 09:44:01 pm »
You should define your drone definition. U need a unit whos can lift enought and battery can live enought. Cheap ones cannot do that.
Offline mobby_6kl
Re: Drone mounting?
« Reply #11 on: March 25, 2023, 11:17:32 am »
I think some drones do have a USB port specifically for attaching various gadgets, although whether or not it'd be able to meaningfully use a thermal camera, I don't know.
Re: Drone mounting?
« Reply #12 on: March 29, 2023, 07:13:20 am »
I was really just looking for a cost effective method of getting a thermal drone, you can just buy one but the price is a bit hefty @£4800 ish whereas a post lockdown almost new hardly used Mavic 2 mini can be had for £200-300 on FB marketplace
