When supplying 12V to the boards some LEDs light, voltages are present and the Tamarisk moves its FFC-flag. The CPU gets slightly warm... everything seems normal but there is no output signal present.
Nothing on the debug UART (which should display messages during booting of the OS), no link-detect pulses on ethernet (PHY is not configured) and no video out.
The seller was a friendly chap which supplied replacement interposer and CPU boards to me, unfortunately the CPU bord needs firmware to do anything. The friendly support from Leopard Imaging supplied me sources and a compiled firmware I could flash, so I now have a working CPU board.
Again I had no luck because it's overflowing the debug UART with error messages.
ERROR (drv_imgs_DRS_Sen i2c_transfer(0x4d, 0x18)
sor.c|DRV_DrsWrite|161): DRV_Drs i2c_transfer(0x4d, 0x20)
Write()
ERROR (drv_imgs_DRS_Sensor.c|DRV_DrsR i2c_transfer(0x4d, 0x20)
ead|194): DRV_DrsRead()
#######LCR data = 0x0
The messages arrive so fast my USB-UART converter can't keep up with the data and looses some characters. Also the webserver is running for a few seconds but is then probably slowed down unusable because of the debug messages. The messages indicate a problem with the communication to the Tamarisk and the Leopard Imaging support suggests to set the parameters on the Tamarisk with the DRS tool.
So now to the Tamarisk part in the next post.
