Finished my oscillator replacement of the Electrophysics 7290 (non-A) posted earlier, and while this video doesn't show a heat source, I've adjusted the target voltage and image parameters a bit so it's better than the first showing. I could still turn the target voltage higher, but it didn't make a big difference, so in the interest of prolonging tube life, I left it at a middling voltage. Worth mentioning that on the 7290, the potentiometer for the target voltage is marked "Volt" only, and is behind the metal flange from the front panel, so you have to remove it to adjust it.
You can see different stuff showing with the differing light sources and the RG1000 filter here, but interestingly, the image lag is different in different bands. In the SWIR band there is a reasonable amount of delay/ghosting (still better than my initial testing), but when I take the filter off and switch light sources, it is noticeably faster response.
