Author Topic: Female charging adapter socket for Flir  (Read 542 times)
Offline UgurTopic starter
  • Country: tr
« on: June 08, 2023, 06:29:25 pm »
Hi guys,
It needs a female charging socket, can you help me find a name or code for it?
« Last Edit: June 08, 2023, 06:31:20 pm by Ugur »
Offline railrun
Re: Female charging adapter socket for Flir
« Reply #1 on: June 08, 2023, 06:42:16 pm »
It is a OEM connector for FLIR, you couldn’t purchase the right one.
Here is the non-OEM product:
MQ172X-4SA-CV(31)
« Last Edit: June 08, 2023, 06:44:25 pm by railrun »
  • Country: tr
« Reply #2 on: June 09, 2023, 06:14:25 am »
Thank you for your answer. yes, the image of this product is slightly different, the adapter input may not fit this socket.
Offline Fraser
« Reply #3 on: June 09, 2023, 03:14:14 pm »
I found the nearest possible equivalent for the original FLIR part and it is the one detailed by Railrun. At the time I discovered it, I suggested that FLIR had a custom connector produced using the MQ172 series as a start point in the design. The MQ172 series are smaller than the FLIR part and the ‘keying’ of the connector is different. I have not been able to find a supplier of the FLIR connector and they have to be robbed from parts donor charging docks and original FLIR power adapters. In some cases, users elect to have a MQ172 series connector installed in the camera and charging docks so that a standard connector is present for adaptions. The plug on the power adapter must also be changed, of course.
Fraser
« Last Edit: June 09, 2023, 03:49:30 pm by Fraser »
The following users thanked this post: Ugur
