Products => Thermal Imaging => Topic started by: railrun on December 26, 2023, 02:02:28 pm
Title: Firmware FLIR Vue Pro
Post by: railrun on December 26, 2023, 02:02:28 pm
I have a Flir Vue on my bench. It powers up, do 2 FFC events and then I just get flickering image. The FLIR logo is fine, so the video signal is fine.
I also have checked the sensor (with a other mainboard from a TAU2) and it is okay.
I also have the FFC event square in the upper right corner appears but it stays on. I have read the thread where Fraser had an similiar problem, but a reset and reset to factory settings didn't help. (https://www.eevblog.com/forum/thermal-imaging/thermal-camera-teardown-the-flir-tau-320-by-fraser/)
So my question is: does any one have a firmware image from a Flir Vue Pro and would share it with me? Is there any information stored in the FPGA or is all stored in the Flash-Memory? The EP4 has also an internal memory, if I read the datasheet correct.
Title: Re: Firmware FLIR Vue Pro
Post by: Logan on December 26, 2023, 02:55:04 pm
To be clear, There will be 2 boards in Vue, one is a traditional Tau board, another is the Vue add-on board, which one is working and which one is not?
Post by: railrun on December 26, 2023, 02:59:51 pm
Sadly the Tau Board, as seen in the pictures.
Post by: Logan on December 26, 2023, 03:10:18 pm
Try this: https://www.eevblog.com/forum/thermal-imaging/how-to-upgrade-flir-tau-firmware/ (https://www.eevblog.com/forum/thermal-imaging/how-to-upgrade-flir-tau-firmware/)
I remember this only suppose to work on fast-frame Tau2 cores.
I tried on two of my Taus, both succeed. But be prepared to recalibrate afterwards.
Post by: railrun on December 26, 2023, 09:42:05 pm
Thank you for the hint, but the FLIR Camera Controller Software only work with "normal" TAU2 cores. When I connect the core as an "LWIR-MWIR" camera it fails to connect. I have monitored the serial communication and after getting the hardware ID it stops.
When I choose UAS it will connect without a problem, but I have just a few settings and no update function.
Post by: svgurus on December 27, 2023, 11:33:07 am
did you connect tau through vpc and 40pin connector? if you use usb of vue board flir gui definitely wont work
Post by: railrun on December 27, 2023, 03:07:21 pm
Of course I habe used the VPC.
Post by: Logan on December 27, 2023, 03:27:09 pm
This means the Tau in Vue is actually a custom firmware... Bad news.
Sorry I cannot help you more.
Post by: 1os on January 09, 2024, 11:26:18 pm
Hi all. Perhaps this will help. If you connect module B to the old software, it will connect in exactly the same way as Tau-2 and you can install the firmware. We need the old interface.
Post by: 1os on January 09, 2024, 11:30:46 pm
