Author Topic: Firmware issue on UNI-T UTi260B  (Read 5820 times)
Offline Mike1983Topic starter
« on: September 13, 2023, 08:58:38 am »
Hello everyone,
yesterday I installed a firmware update on my UNI-T UTi260B.
Unfortunately, it now gets stuck at 100% during startup.
In the console, I receive the following message about every second:
imageListUpdate()
Cannot find the director
Regrettably, I don't have a backup of the original firmware.
That's why I'm reaching out to ask if you could send me your backups or firmware.
I would try them out in the hope that one of them works. Thank you in advance.
Best regards from Germany
Mike
Offline Veteran68
Re: Firmware issue on UNI-T UTi260B
« Reply #1 on: September 13, 2023, 06:00:57 pm »
One of several threads here in the forum with this issue:
https://www.eevblog.com/forum/thermal-imaging/uti260b-uti690b-firmware-backup-script
Several people have uploaded their firmware. You want to be sure you match the major version of your original firmware. This is usually a soft "bricking" caused by installing the wrong firmware version. For example, installing v2.x firmware on a v.1x device. This isn't officially documented and even Banggood provided an incorrect version that bricked my UTi690B (same as the 260B). Since you already have console access you just need to copy over the main firmware file back to your unit as described in those threads. Also the original splash screen image if you want it back.
The following users thanked this post: MHTSOS
« Reply #2 on: September 14, 2023, 03:00:44 pm »
Thanks!
I've found the needed version, my 260B is working again.
BR
Mike
Offline tunguyengevn
« Reply #3 on: August 09, 2024, 09:54:24 pm »
Hi.
Do u have uti 260B firmware ? and know how to upload to device?
Thanks.
« Reply #4 on: August 10, 2024, 01:04:27 pm »
I will check it today and provide you a download link.
Mike
« Reply #5 on: August 11, 2024, 11:47:20 am »
you can download the backup firmware from here: https://cloud.ordnung.family/s/kFG226Dy46TCy5m
BR
Michael
Offline Almo
  • Country: eg
« Reply #6 on: March 31, 2025, 03:33:41 am »
I am facing exactly the same problem you fast some time ago with my uti260b which stuck on loading screen after firmware upgrade.
I also did not made backup of my firmware before upgrading  |O, can you please re-share the firmware you found and give a brief explanation how did you solved your device problem.
Million thanks.
Alex
« Reply #7 on: March 31, 2025, 06:56:38 am »
u can find my backup here: https://cloud.ordnung.family/s/6eLp9qZJcsrYmj5
You have to copy the application and maybe some libs (check the update script that u used. There is a list of files which were updated) on a sd card.
Connect a RS232 (UART) to the camera (you have to open the camera). Which this connection you can open up a serial console to linux. Then copy the application and the libs from the sd card to the flash.
good luck
Mike
Offline Almo
  • Country: eg
« Reply #8 on: March 31, 2025, 07:18:02 pm »
Thank you so much Mike for your support. I can't say I fully understand how to do it as I am not an expert as you. Still I did many ordinary repairs, so maybe it is time for me to learn new staff.
Just in case you had some free time, can you elaborate more. I will search for details on how to do each step. I am mainly talking about flashing the chip that holds the bin file.
« Last Edit: March 31, 2025, 08:09:17 pm by Almo »
Offline MM260b
« Reply #9 on: April 17, 2025, 05:40:20 pm »
unfortunately in my 260B I  - thoughtlessly - tried to upgrade the firmware from version 1.1.6 to version 2. Result: soft brick. I don't have my backup... Now I connected using Putty and tried solutions from other threads (FWBackup):
cp -r /media/mmcblk0p1/FWBackup/etc/ /etc/
cp -r /media/mmcblk0p1/FWBackup/usr/lib/ /usr/lib/
cp -r /media/mmcblk0p1/FWBackup/ /root/
[/i]
Unfortunately it still hangs on "Loading ..." screen.
The link to your files does not work (error 404). Could you share your backup again and write a few words on how to restore it?
Best regards
Edit after 3 hours:
Done - I was able to upload version 1.2.6
There were errors in the copy commands.
Instead of:
It should be:
cp -r -f /media/mmcblk0p1/FWBackup/etc/ /
cp -r -f /media/mmcblk0p1/FWBackup/usr/lib/ /usr/
cp -r -f /media/mmcblk0p1/FWBackup/root/ /
I'm not sure about the temperature calibration though.
And maybe is newer version FW 1.x.x is for the 260B ?
« Last Edit: April 17, 2025, 10:01:45 pm by MM260b »
