Author Topic: Flir B300  (Read 1680 times)
Offline chili_redTopic starter
Flir B300
« on: October 13, 2018, 03:30:43 pm »
I recently acquired a gently used B300 software version 9.4.5 and have gone through modding all the config files.
Even though I've changed the .cfg files to include options like "Circle measurement" I'm only getting a few of the options to appear on the menu screen.
The Circle tool does not show up, same with Arrow and a couple others, is there a limitation as to how many items can be shown on the menu at the same time?
I've also enabled video recording, it works but the frame rate is only around 6fps "depending on speed of sd card", was wondering if this also a hardware or OS limitation, as my modded E40 does 30fps recording without any problem.
Here's a copy of the Appcore.d cfg file.
These are unmodded, original.
# Prodconf - Measurement active + 5 mbox's and 5 spots + 1 isotherm
# + radiometric store, compatible radiometric format
.caps entry
.caps.config entry
.caps.config.name text "app B300"
.caps.config.revision text "2.11B"
.caps.config.image entry
.caps.config.image.framegrab entry
.caps.config.image.framegrab.fusion entry
.caps.config.image.framegrab.fusion.enabled bool true
.caps.config.image.sensor entry
.caps.config.image.sensor.enabled bool true
.caps.config.image.services entry
.caps.config.image.services.store entry
.caps.config.image.services.store.enabled bool true
.caps.config.image.services.store.radiometric entry
.caps.config.image.services.store.radiometric.enabled bool true
.caps.config.image.services.store.incompatible entry
.caps.config.image.services.store.incompatible.enabled bool false
.caps.config.image.services.store.incompatible.level int32 0
.caps.config.image.settings entry
.caps.config.image.settings.enabled bool true
.caps.config.image.settings.downsample bool false
.caps.config.image.settings.resIR int32 320
.caps.config.image.sysimg entry
.caps.config.image.sysimg.alarms entry
.caps.config.image.sysimg.alarms.enabled bool true
.caps.config.image.sysimg.alarms.measfunc entry
.caps.config.image.sysimg.alarms.measfunc.enabled bool false
.caps.config.image.sysimg.alarms.measfunc.maxCount int32 0
.caps.config.image.sysimg.alarms.humidity entry
.caps.config.image.sysimg.alarms.humidity.enabled bool true
.caps.config.image.sysimg.alarms.humidity.maxCount int32 1
.caps.config.image.sysimg.alarms.insulation entry
.caps.config.image.sysimg.alarms.insulation.enabled bool true
.caps.config.image.sysimg.alarms.insulation.maxCount int32 1
.caps.config.image.sysimg.irMarkers entry
.caps.config.image.sysimg.irMarkers.enabled bool false
.caps.config.image.sysimg.irMarkers.spot entry
.caps.config.image.sysimg.irMarkers.spot.enabled bool false
.caps.config.image.sysimg.irMarkers.spot.maxCount int32 0
.caps.config.image.sysimg.irMarkers.arrow entry
.caps.config.image.sysimg.irMarkers.arrow.enabled bool false
.caps.config.image.sysimg.irMarkers.arrow.maxCount int32 0
.caps.config.image.sysimg.irMarkers.box entry
.caps.config.image.sysimg.irMarkers.box.enabled bool false
.caps.config.image.sysimg.irMarkers.box.maxCount int32 0
.caps.config.image.sysimg.measureFuncs entry
.caps.config.image.sysimg.measureFuncs.enabled bool true
.caps.config.image.sysimg.measureFuncs.diff entry
.caps.config.image.sysimg.measureFuncs.diff.enabled bool true
.caps.config.image.sysimg.measureFuncs.diff.maxCount int32 1
.caps.config.image.sysimg.measureFuncs.diff.calcMask int32 65526
.caps.config.image.sysimg.measureFuncs.isotherm entry
.caps.config.image.sysimg.measureFuncs.isotherm.enabled bool true
.caps.config.image.sysimg.measureFuncs.isotherm.calcMask int32 20
.caps.config.image.sysimg.measureFuncs.isotherm.dual bool false
.caps.config.image.sysimg.measureFuncs.isotherm.fixScale bool false
.caps.config.image.sysimg.measureFuncs.isotherm.interval bool true
.caps.config.image.sysimg.measureFuncs.isotherm.invInterval bool false
.caps.config.image.sysimg.measureFuncs.isotherm.maxCount int32 1
.caps.config.image.sysimg.measureFuncs.mbox entry
.caps.config.image.sysimg.measureFuncs.mbox.enabled bool true
.caps.config.image.sysimg.measureFuncs.mbox.calcMask int32 1924
.caps.config.image.sysimg.measureFuncs.mbox.maxCount int32 5
.caps.config.image.sysimg.measureFuncs.mcircle entry
.caps.config.image.sysimg.measureFuncs.mcircle.enabled bool false
.caps.config.image.sysimg.measureFuncs.mcircle.calcMask int32 1924
.caps.config.image.sysimg.measureFuncs.mcircle.maxCount int32 0
.caps.config.image.sysimg.measureFuncs.mline entry
.caps.config.image.sysimg.measureFuncs.mline.enabled bool false
.caps.config.image.sysimg.measureFuncs.mline.calcMask int32 1924
.caps.config.image.sysimg.measureFuncs.mline.maxCount int32 0
.caps.config.image.sysimg.measureFuncs.reftemp entry
.caps.config.image.sysimg.measureFuncs.reftemp.enabled bool true
.caps.config.image.sysimg.measureFuncs.reftemp.calcMask int32 1924
.caps.config.image.sysimg.measureFuncs.reftemp.maxCount int32 1
.caps.config.image.sysimg.measureFuncs.script entry
.caps.config.image.sysimg.measureFuncs.script.enabled false
.caps.config.image.sysimg.measureFuncs.script.maxCount int32 0
.caps.config.image.sysimg.measureFuncs.spot entry
.caps.config.image.sysimg.measureFuncs.spot.enabled bool true
.caps.config.image.sysimg.measureFuncs.spot.calcMask int32 514
.caps.config.image.sysimg.measureFuncs.spot.maxCount int32 5
.caps.config.image.sysimg.visualMarkers entry
.caps.config.image.sysimg.visualMarkers.enabled bool false
.caps.config.image.sysimg.visualMarkers.spot entry
.caps.config.image.sysimg.visualMarkers.spot.enabled bool false
.caps.config.image.sysimg.visualMarkers.spot.maxCount int32 0
.caps.config.image.sysimg.visualMarkers.arrow entry
.caps.config.image.sysimg.visualMarkers.arrow.enabled bool false
.caps.config.image.sysimg.visualMarkers.arrow.maxCount int32 0
.caps.config.image.sysimg.visualMarkers.box entry
.caps.config.image.sysimg.visualMarkers.box.enabled bool false
.caps.config.image.sysimg.visualMarkers.box.maxCount int32 0
.caps.config.image.targetNoise entry
.caps.config.image.targetNoise.enabled bool false
.caps.config.image.targetNoise.targetNoiseMk int32 0
.caps.config.image.zoom entry
.caps.config.image.zoom.enabled bool true
.caps.config.image.zoom.maxFactor double 2
.caps.config.system entry
.caps.config.system.focus entry
.caps.config.system.focus.laser entry
.caps.config.system.focus.laser.updateFocus entry
.caps.config.system.focus.laser.updateFocus.enabled bool true
# ID 48800961
# CRC01 0ccab180
And the Gui.d cfg file,
# Generated at 2010-01-27 15:23:34
.caps entry
.caps.config entry
.caps.config.name text "GUI B300"
.caps.config.docToolbar entry
.caps.config.docToolbar.enabled bool true
.caps.config.docToolbar.sketch bool false
.caps.config.docToolbar.textComment bool false
.caps.config.docToolbar.voiceComment bool true
.caps.config.emissivity entry
.caps.config.emissivity.enabled bool true
.caps.config.emissivity.table text "BCAM"
.caps.config.emissivity.tableFile bool true
.caps.config.fusion entry
.caps.config.fusion.aboveActive bool false
.caps.config.fusion.belowActive bool false
.caps.config.fusion.enabled bool true
.caps.config.fusion.picInPicFusion bool true
.caps.config.fusion.pipPositionLocked bool true
.caps.config.fusion.thermalFusion bool false
.caps.config.laser entry
.caps.config.laser.enabled bool true
.caps.config.laser.positionMarker bool true
.caps.config.measure entry
.caps.config.measure.enabled bool true
.caps.config.measure.objParams entry
.caps.config.measure.objParams.enabled bool true
.caps.config.measure.objParams.setReflected bool false
.caps.config.measure.screening entry
.caps.config.measure.screening.enabled bool false
.caps.config.modes entry
.caps.config.modes.enabled bool true
.caps.config.modes.program bool false
.caps.config.modes.panorama bool false
.caps.config.modes.simultaneous bool true
.caps.config.modes.video bool false
.caps.config.save entry
.caps.config.save.enabled bool true
# ID 48800961
# CRC01 57f9da7a
« Last Edit: October 13, 2018, 03:51:43 pm by chili_red »
Re: Flir B300
« Reply #1 on: October 13, 2018, 03:38:18 pm »
Excellent image quality otherwise.
Close up of insect fogger after cooling a bit "we've been inundated by mosquitoes this year  :scared:"
Down our street
Probably can tell what this is  :)
