Author Topic: Can I disable the color pattern indicator on Flir ix?  (Read 2565 times)
Offline sam1275Topic starter
« on: November 05, 2016, 01:05:06 am »
Hi everyone.
Can I disable the color pattern indicator on my Flir ix(on the bottom of the screen)?
Also, how to change the font size?
Thank you.
« Last Edit: November 05, 2016, 04:31:50 am by sam1275 »
Offline joe-c
    • Joe-c.de
Re: Can I disable the color pattern indicator on Flir ix?
« Reply #1 on: November 05, 2016, 09:32:38 am »
for that you have to change the firmware and this is not a simple thing.
The images contains a normal preview (what you see in browser) and a raw thermal frame, this can be translated with some applications and can be stored without the scale if wanted.
Freeware Thermal Analysis Software: ThermoVision_Joe-C
Some Thermal cameras: Kameras
« Reply #2 on: November 05, 2016, 04:04:58 pm »
Thank you.
I tried every file I can open and didn't find those settings, so maybe it's hard coded :horse:
Offline joe-c
    • Joe-c.de
« Reply #3 on: November 05, 2016, 10:05:03 pm »
thats possible.
but, what exactly you want? do you want this only on images, or did you want this on Screen.
if on Screen, maybe this two Telnet commands help, if your FW support this:
rset .ui.userSettings.hideAll true
rset .ui.userSettings.hideGraphics true
« Reply #4 on: November 06, 2016, 05:16:30 am »
thats possible.
Thank you, I want to hide the color palette, and make the main temperature indicator very small, both on the screen and on the final picture, because I feel they use too much space.
