Poll
241 (26.5%)
425 (46.8%)
43 (4.7%)
41 (4.5%)
158 (17.4%)
Total Members Voted: 749
Author Topic: Flir E4 Thermal imaging camera teardown  (Read 2649876 times)
Offline bean_dip
« Reply #75 on: October 21, 2013, 12:21:36 am »
So, I was digging through more of the update.  Saw this...not sure if it refers to just image files or all of them, but it has a switch for forcing a file to load with a broken CRC...
usage: ftest [-q] [-n nr] [-e] [-x] [-i imageid] [-g groupid] [-s siteid]
             [-l 0|1] [-t <tag>:<subtag>:<rev>:<file>] [-j <file>] [-d <tag>]
             [-m] [-f] [-c <file>] [-r <x>:<y>:[e:]<file>] [-a <file>]
             [-v <file>] [-b <file>] <image1> [image2] ...
  -q   quiet mode, only print error messages (on stderr)
  -n   read file <nr> in seq file, or \"iter\" to iterate whole file
  -e   extract parts to file
  -x   extract each image in a sequence
  -i   replace EXIF image ID with <imageid>, \"rand\" creates new
  -g   replace EXIF group ID with <groupid>, \"rand\" creates new
  -s   replace EXIF site ID with <siteid>, \"rand\" creates new
  -l   replace stitchLast with 0 or 1
  -t   replace/add <tag> with data from <file> at revision <rev>
  -j   replace JPEG pixels with data from <file>
  -d   delete <tag> from file
  -m   force map stats calc on image
  -f   force loading by ignoring broken CRCs
  -c   create color JPEG <file> from FFF data
  -r   rescale to size <x>x<y> in <file> (add :e: for exact rescale)
  -a   resave using original format to <file>
  -v   save IR pixels as temp values as csv data in <file>
  -b   save image1, image2,... to seq <file> (.csq = compressed)
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #76 on: October 21, 2013, 12:30:58 am »
Here are the pinouts I've determined so far on the hidden bottom connector of the i7, for those interested. Is such a connector present on the E-series?
BTW I'm pretty sure the i7 hack was using rset - image resolution, noise turned off, so if you can find a console UART or USB networking mode you may be in.
The hidden menu was 2 keys, one of which was one of the arrows, pressed after powerup.
As the front keypad acts like a keyboard ( You can fake buttons with bt.exe and enter/arrows navigate WinCe menus clears menus ), it may be a case of hitting keys at a certain time rather than hplding down from powerup.
rset does have an optional password so could be that making it fail.
Still unsure of the relationship between resources and the files.
Day Job: Mostly LEDs
Online mrflibble
« Reply #77 on: October 21, 2013, 12:31:09 am »
Looking at facet_Z3.rcc would seem to suggest they are using Qt for their gui. Which is a good thing, as Qt doesn't suck. :P And it would also seem to suggest that at least that part was made in Sweden.
As for crc ... I noticed in camera.cmd it does this:
Check if crc have changed
kitcrc -c \FlashBFS\system\kits.d\appkit.rev
[*FAIL*][$GOTO failed2]
kitcrc -c \FlashBFS\system\kits.d\prodkit.rev
So you might be able to use kitcrc to adjust things to your liking. At any rate, camera.cmd is full of inspiration. ;)
Duh. blind. of course they use Qt.
./FlashBFS/system/QtDeclarative4.dll
./FlashBFS/system/QtCore4.dll
./FlashBFS/system/QtGui4.dll
./FlashBFS/system/QtNetwork4.dll
./FlashBFS/system/QtScript4.dll
Offline bean_dip
« Reply #78 on: October 21, 2013, 12:58:44 am »
appcore.exe has a string Reference to "Lock, Unlock: 1235"...possibly related?
Let me know if I'm just clogging up the thread with useless junk...
Offline nowlan
« Reply #79 on: October 21, 2013, 05:04:08 am »
From http://www.termsys.demon.co.uk/vtansi.htm
ANSI/VT100 Terminal Control Escape Sequences
Query Cursor Position   <ESC>[6n
    Requests a Report Cursor Position response from the device.
« Reply #80 on: October 21, 2013, 09:03:29 am »
Found another TX port, which spits out " \> [6n" consistently on hard boot. Can't get any of the other ports to respond, though.
That looks like the console port - run a terminal program and send carriage returns to pins to find RXD until you see that prompt repeating.
The E4 gives a short version string at boot so may be slightly different :
FLIR Command Line Interpreter
Version 0.4.3 running on WinCE 6.0
« Last Edit: October 21, 2013, 10:20:22 am by mikeselectricstuff »
« Reply #81 on: October 21, 2013, 10:37:47 pm »
Doesn't look like those .cfg files do much - it will start with the file not present - suspect they are debug output etc.
Looking at what  & when it reads from eeprom. Looks like most records have a 2 byte check at the end - anyone good at CRC-spotting? CRC in bold.
Quite a few sections get read multiple times - I've omitted duplicates
AEW is eeprom address
D0W is realtime clock
 Following read at power-up only
Time   Restart   Address   Data
-388.0us      AEW   80
-40.78us   X   AFR   0B 91 39 00 00 00 00 00 00 00 00 00 00 00 00
1.860s      AEW   40
1.860s   X   AFR   54 31 39 38 32 38 33 00 00 00 31 39 39 36 37 37 33 30 00 00 31 30 00 00 00 00 00 00 00 00 F7
1.900s      D0W   0
1.901s   X   D1R   27 54 23 01 21 10 13  ; RTC
1.930s      D0W   0
1.931s   X   D1R   27 54 23 01 21 10 13
2.246s      AEW   0
2.246s   X   AFR   46 4C 49 52 20 45 34 00 00 00 00 00 00 00 00 00 00 00 00 00 36 33 39 30 31 2D 30 31 30 31 00 00 00 00 00 00 36 33 39 30 33 37 37 31 00 00 32 30 31 33 2D 31 30 2D 30 32 00 00 30 31 00 00 DC C7
4.419s      AEW   C0
4.419s   X   AFR    50 00 3C 00 00 06 00 00 00 00 00 00 00 00 8C 06
50 00 = 80 decimal, 3C 00 = 60 decimal - VERY INTERESTING!!! also 60Hz/6=10 - could the 06 be framerate?
Following read at app restart from console, and after above at powerup
1.233s      AEW   A0
1.234s   X   AFR   54 31 39 38 33 30 34 00 00 00 36 33 38 30 34 35 38 35 00 00 30 31 00 00 FF FF FF FF FF FF FB 98
1.251s      AEW   0
1.252s   X   AFR   46
1.254s      AEW   D0
1.255s   X   AFR   FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1.482s      AEW   C0
1.483s   X   AFR   50 00 3C 00 00 06 00 00 00 00 00 00 00 00 8C 06
3.661s      AEW   0
3.662s   X   AFR   46 4C 49 52 20 45 34 00 00 00 00 00 00 00 00 00 00 00 00 00 36 33 39 30 31 2D 30 31 30 31 00 00 00 00 00 00 36 33 39 30 33 37 37 31 00 00 32 30 31 33 2D 31 30 2D 30 32 00 00 30 31 00 00 DC C7
3.673s      AEW   0
3.674s   X   AFR   46
3.675s      AEW   0
3.676s   X   AFR   46 4C 49 52 20 45 34 00 00 00 00 00 00 00 00 00 00 00 00 00 36 33 39 30 31 2D 30 31 30 31 00 00 00 00 00 00 36 33 39 30 33 37 37 31 00 00 32 30 31 33 2D 31 30 2D 30 32 00 00 30 31 00 00 DC C7
19.86s      AEW   A0
19.86s   X   AFR   54 31 39 38 33 30 34 00 00 00 36 33 38 30 34 35 38 35 00 00 30 31 00 00 FF FF FF FF FF FF FB 98
29.66s      AEW   40
29.66s   X   AFR   54 31 39 38 32 38 33 00 00 00 31 39 39 36 37 37 33 30 00 00 31 30 00 00 00 00 00 00 00 00 F7 A8
hang on a minute.... I think I spotted the check method
50 00
3c 00
00 06
00 00
00 00
Check is 8C 06
It's a simple 16 bit checksum FFS!!!!
Let's check with another  one to see how the carry works..
54 31
39 38
32 38
33 00
00 00
31 39
39 36
37 37
33 30
00 00
31 30
00 00
00 00
00 00
00 00
F7 A8
Add them up  (Lsb:Msb) - 1A8F7 - Yesss!
« Reply #82 on: October 21, 2013, 10:51:07 pm »
Hmmm - changed eeprom and it changed it back....!
Offline neggles
  • I like to make things
« Reply #83 on: October 22, 2013, 12:02:03 am »
That's... odd. It must be cross-checking with something on the flash so you can't just change one place.
But if it's just going to overwrite the eeprom, why even have the eeprom?!
« Reply #84 on: October 22, 2013, 12:50:57 am »
No carriage return, but sending anything to the port above the TX2 port (likely RXD) makes it appear on the serial monitor -- that doesn't happen with any of the other ports. Question marks don't do anything -- perhaps the [6n is asking the device what position the keyboard is in, so that it can trigger CLI mode?
Had to enable NL & CR in terminal!  :palm:
For comparison, remember this is from i7, not E4!
?         alias     attrib    beep      bootdeletecall      cd        chdir
choice    cls       copy      date      del       delete    delay     dir
dirs      echo      echos     echoerr   echoserr  erase     exit      for
free      goto      help      history   if        irqlog    memory    md
mkdir     move      path      pause     popd      prompt    pushd     rd
rem       ren       rename    restart   replace   rmdir     rcd       rpwd
rls       rset      rclone    rcreate   rdelete   rdump     rfind     rpatch
rreload   screen    set       shift     start     time      timer     type
ver
\>help
List of all available commands (+ description)
  command /?     For more information on a specific command
?        List all available commands without description).
ALIAS    Sets, removes or shows aliases.
ATTRIB   Displays or changes file attributes.
BEEP     Beep the speaker.
CALL     Calls one batch program from another.
CD       Displays the name of or changes the current directory.
CHOICE   Waits for the user to choose one of a set of choices.
CLS      Clears the screen.
CMD      Starts a new instance of the FLIR command line interpreter.
COPY     Copies one or more files to another location.
DATE     Displays or sets the date.
DELETE   Deletes one or more files.
DIR      Displays a list of files and subdirectories in a directory.
ECHO     Displays messages, or turns command echoing on or off.
ERASE    Deletes one or more files.
EXIT     Quits the CMD.EXE program (command interpreter).
FOR      Runs a specified command for each file in a set of files.
FREE     (free) disc space.
GOTO     Directs the FLIR command line interpreter to a labeled line in
         a batch program.
HELP     Provides Help information for FLIR commands.
HISTORY  List all commands which has been used
IF       Performs conditional processing in batch programs.
MD       Creates a directory.
MKDIR    Creates a directory.
MOVE     Moves one or more files from one directory to another
         directory.
PATH     Displays or sets a search path for executable files.
PAUSE    Suspends processing of a batch file and displays a message.
POPD     Restores the previous value of the current directory saved by
         PUSHD.
PROMPT   Changes the command prompt.
PUSHD    Saves the current directory then changes it.
RD       Removes a directory.
REM      Records comments (remarks) in batch files.
REN      Renames a file or files.
RENAME   Renames a file or files.
REPLACE  Replaces files.
RMDIR    Removes a directory.
SCREEN   Move cursor and optionally print text.
SET      Displays, sets, or removes FLIR command line interpreter environment variables.
SHIFT    Shifts the position of replaceable parameters in batch files.
START    Starts a separate window to run a specified program or command.
         Executes command.
TIME     Displays or sets the system time.
TIMER    Allow the use of ten stopwatches.
TYPE     Displays the contents of a text file.
VER      Displays the FLIR command line interpreter and Windows CE version.
Time to explore resources with rls and rcd...
« Reply #85 on: October 22, 2013, 12:53:34 am »
fvd.exe and fvd.dll look interesting - I think this is the first thing run at boot time - contains the downsampling message as well as references to eeprom checksum error.
Offline Psi
« Reply #86 on: October 22, 2013, 01:15:30 am »
Here's hoping it didn't just increment a tamper counter.  Strike 1  hehe.
« Reply #87 on: October 22, 2013, 09:04:21 am »
\>rls system
MACaddr         "censored"
eeprom
focus
fvd
powerButton
restart                    false
restartDelay                   1
sync                          ""
tempsens
tempsensActive              true
tempsensError              "0 0"
tempsensValid               true
time
usbmode                    "MSD"
webpasswd                "IRCAM"
Still trying to figure out how to use rls/rcd...
The resource stuff like a tree. rcd is a convenient way of sitting at a deep level so you don't need to specify the full path.
e.g. to see teh time value you can do
rls system.time
or rcd system
rls time
rls [path] -r will show the whole  subtree
-l shows more info including attributes
rset allows values to be changed once you've used rls to find the key and format
rdump allows a tree to be dumped to a file
most of these utils have some inbuilt help using /?
Also have a look in the flashBFS\system dir for other executables.
Offline amyk
« Reply #88 on: October 22, 2013, 10:07:51 am »
Another possibility is that there is data stored in the sensor itself (possibly in OTP), as is often done for regular camera chips.
Offline Pinkus
« Reply #89 on: October 22, 2013, 01:29:42 pm »
I accidentely stumbled upon the attached file.
It might be helpful in some way (commands/parameters), it might not.
« Reply #90 on: October 22, 2013, 02:54:32 pm »
Yes - that's the one linked from the PDF I mentioned earlier - some parts are out of date but some useful snippets in there
Offline tom66
  • Electronic Engineer & Hobbyist
« Reply #91 on: October 22, 2013, 03:26:02 pm »
wonder how difficult it would be to decompile the *.exe and figure out what's happening when the downsampling messages are printed?
« Reply #92 on: October 22, 2013, 04:18:04 pm »
fvd.exe and fvd.dll aren't very big, so should be fairly doable, given a decent cross-referencing diassember
Offline tom66
« Reply #93 on: October 22, 2013, 06:33:24 pm »
It is an ARM processor though so availability of those for EXE files may be scarce, probably IDA Pro will do it but I don't know.
Offline AF6LJ
« Reply #94 on: October 22, 2013, 10:09:13 pm »
Good Video, I enjoyed watching it.  :)
Sue AF6LJ
Test Equipment Addict, And Proud Of It.
Offline bean_dip
« Reply #95 on: October 22, 2013, 11:57:37 pm »
I was looking at them with the demo of IDA Pro. It does have the option for ARM but you can't access it in the demo...it would do it as a generic binary and I got what looked like assembly, but I'm not good enough to make heads or tails of it. I was just digging out the strings from the exe's in the update and posting them earlier since I still don't have my camera.
Offline bean_dip
« Reply #96 on: October 24, 2013, 02:16:49 am »
Okay,
I'm not good enough to make heads or tails of a lot of what I'm seeing here.  I don't have a full version of IDA Pro so I can't disassemble for ARM, but I can as a generic binary.  I'm still learning but maybe this will mean something to someone else.  Attached are the results of IDA's disassembly and code generation.
Offline nowlan
« Reply #97 on: October 24, 2013, 06:34:32 am »
The free/demo version of ida pro only do windows 32 x86 code.
At best you can read the strings in the binary.
Im sure some others around here have the pro version, required for rigol hacks.
Dont know any arm decompilers off the top of my head.
Online Ed.Kloonk
« Reply #98 on: October 24, 2013, 08:17:02 am »
Sorry for being late to the party. Wanted to say thanks Mike for this vid and the review. And the x-ray machine vid.
I watch them here and there after downloading them (slowly) and forget to say ta!
Offline nitroxide
« Reply #99 on: October 24, 2013, 08:30:37 am »
I've been silently following the E4 related threads for some time. Must say, juicy information :)
I don't have an E4 (yet... -  that may change :) ) but I've tried to put together some bits of information that I've found around in this thread. IMHO the simple way to go is using the Web Interface (you can access most, if not all, camera settings from there - including a special Service Menu) - all menus conveniently listed in FlashBFS/system/web/ and sub-folders
..and if you send a <space> to the UART during boot....
SETTINGS:
0) IP address: 0.0.0.0
1) Subnet Mask: 0.0.0.0
2) Boot delay: 1 seconds
3) DHCP: Enabled
4) Reset to factory default configuration
5) Autoboot: NK from NOR
6) MAC address: 00:40:7F:0B:91:39
7) Host connection: (USB MSD)
Option 7 may be intersting - options are USB BSD, ETHERNET and USB RNDIS, which provides virtual ethernet over USB - fairly sure the latter is what enabled the i7 hack
As Mike said, if 7) is changed to USB RNDIS (and may be that IP address and subnet mask also need to be set manually and DHCP disabled - if the PC doesn't assign them automatically over USB), the web service can be accessed.
Now, as for the A310 FLIR (the attached PDF with Technical Notes), it must be password protected, but I see that the password is already known: webpasswd "IRCAM"
Therefore (stating the obvious) the login info should be:
Username: flir
Password: IRCAM
Could someone try this?
P.S. With the risk of being Cpt. Obvious, I just want to be involved in this and help if I can do so ;D
