Poll
250 (26.8%)
433 (46.4%)
45 (4.8%)
46 (4.9%)
160 (17.1%)
Total Members Voted: 768
Author Topic: Flir E4 Thermal imaging camera teardown  (Read 2842727 times)
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #125 on: October 24, 2013, 09:35:39 pm »
Correction : FTP login flir / 3vlig does work, but not on all FTP clients - Windows command line FTP works, FTPsurfer doesn't
BTW flir/IRCAM doesn't work on web interface
Day Job: Mostly LEDs
« Reply #126 on: October 24, 2013, 09:37:06 pm »
Another thing. It would be really interesting (at least for me if not for others also) what would happen if you enable the UVC mode for USB. Does this result in a USB video stream of thermographic video (basically like webcam)?
You can do that with the standard, unmodified product, as mentioned in the review.  Just plug in & it appears as a digital camera device & you can record video. Framerate is a bit messed up but it does work.
Offline nitroxide
« Reply #127 on: October 24, 2013, 09:38:37 pm »
Oops, my bad! I may have skipped parts of the review...  :-[
Online Fraser
« Reply #128 on: October 24, 2013, 10:20:56 pm »
Hey Mike,
Just to let you know that your tear down video and investigation is being watched closely by comapnies in the TIC industry. Three separate technical officers have mentioned it to me recently  ;)   You are causing a bit of a stir  :-+
« Last Edit: October 24, 2013, 10:23:07 pm by Aurora »
Offline ixfd64
    • Facebook
« Reply #129 on: October 24, 2013, 10:26:12 pm »
If you're going to void the warranty, you might as well go the whole nine yards. ;D
« Reply #130 on: October 24, 2013, 10:29:09 pm »
OK Useful-ish Hack stage 1 is achieved.
UART console : usbfn RNDIS
Plug USB into PC (having loaded Flir device drivers from http://flir.custhelp.com/app/account/fl_download_software, PC softare (Thermography) -> device drivers)
Web login to service menu (192.168.0.2) with user flir, PW 3vlig
Enable service mode - reboots camera into service mode (takes about 45 secs)
Some E8 functions now available -Auto hotspot, Auto coldspot, more colour pallettes
Oh, and.....
320x240 resolution
Boot text in service mode
FVD_Init: Downsampling setting: 0x00
FVD_Init: re-read the hardware information x: 320, y: 240
On next  power-up boot :
APPLAUNCHER: Starting usb charge App
ProgressApp expecting 301 events
FVD_Init: Downsampling setting: 320 240
Timeprint (3518)
POST 20131025 00:08:42 -      appcore.exe: Application started
POST 20131025 00:08:44 -      appcore.exe: TSFpa: 303.000000 K
FVD_Init: re-read the hardware information x: 80, y: 60
Unfortunately sleep/restore doesn't seem to work to keep it in service mode as long as battery connected  :(
The following users thanked this post: chili_red
Online Fraser
« Reply #131 on: October 24, 2013, 10:33:19 pm »
RESPECT  :-+
« Reply #132 on: October 24, 2013, 10:33:31 pm »
Hey Mike,
I wouldn't expect any less  8)
Saves them paying for one of those expensive reports from people like Systemplus.
Online Fraser
« Reply #133 on: October 24, 2013, 10:41:13 pm »
If you achieve your objective, I predict a very sharp increase in E4 sales ...... FLIR will have a major seller on their hands. I wonder how they will feel about that ?
I am aware that industry will continue to buy the full cost units due to calibration etc, but the E4 would become the cheapest 320x240 on the market and built by a top class manufacturer ! The Consumer TIC Holy Grail.
Very interesting times  :)
Oh and forget about the black helicopters.... it will be the white van snatch squad from FLIR that you need to worry about.  :-DD
« Last Edit: October 24, 2013, 10:48:48 pm by Aurora »
Offline mrflibble
« Reply #134 on: October 24, 2013, 10:44:20 pm »
Well done!   :-+
So basically an old school IP-over-USB + use the telnet/web/whatever interface and you're in service mode? awesome!  ;D
« Reply #135 on: October 24, 2013, 10:45:39 pm »
One minor issue is in RNDIS mode you can't get USB access to the drive, but you can get at the files via FTP in net mode - an advantage of this is you can take pics and pull files with USB connected - in normal mode the filesystem can only be mounted by the PC or the camera at any time.
but you can do
usbfn Mass_Storage_Class
via telnet, which reverts it to mass storage ( and dumps the net connection, obviously)
If you only have Telnet, be careful with spelling as any misspelling will dump the RNDIS link but not start MSD
Offline nitroxide
« Reply #136 on: October 24, 2013, 10:52:18 pm »
That was quick. Good job Mike!  ;D
Have you tried the RNDIS_UVC_MSD mode instead of RNDIS?
On another topic, I've made some good progress on Hidden Service Menu investigation, but I'm too tired to finalize this. If someone wants to give it a try - disassemble facet_ui_qml.dll and search for "hidden" string.
Offline bean_dip
« Reply #137 on: October 24, 2013, 10:53:28 pm »
Much respect Mike!
I'm still playing around with key combinations...nothing great yet, but while charging if you press "Left" and "Right" at the same time you get charge statistics under the charging icon.  But, this does verify the presence of hidden key sequences.
« Reply #138 on: October 24, 2013, 10:53:52 pm »
The only thing stopping this being done without opening the unit is finding the magic way to get to teh hidden menu to enable RNDIS.
..and of course potentially the next FLIR firmware update....
« Reply #139 on: October 24, 2013, 11:03:45 pm »
doesn't seem to work - it won't let me copy or FTP off usbfn.exe to look for strings
Offline tom66
  • Electron Fiddler, FPGA Hacker, Embedded Systems EE
« Reply #140 on: October 24, 2013, 11:05:09 pm »
OK, the E4 is seriously tempting me...
I expect a hackable E4 would not lead to a significant reduction in E8 sales, but would lead to a large increase in E4 sales to the hobbyist/budget market.
Offline Pinkus
« Reply #141 on: October 24, 2013, 11:05:45 pm »
Deleted - Sorry, I wrote rubbish .....  its too late now: 1:10 am
« Last Edit: October 24, 2013, 11:10:27 pm by PeterK13 »
« Reply #142 on: October 24, 2013, 11:12:09 pm »
http://flir.custhelp.com/app/account/fl_downloads
Software -> PC Software (Thermography) -> FLIR Device drivers -> X86 or x64 as appropriate
You do need to register.
Offline nitroxide
« Reply #143 on: October 24, 2013, 11:13:29 pm »
Direct link to drivers: http://cdn.cloud.flir.se/swdownload/assets/other/flir_device_drivers.exe
Both x86 and x64 seem to point to the same file - correct me if I'm wrong.
Offline Pinkus
« Reply #144 on: October 24, 2013, 11:16:12 pm »
You bet! I already placed my order. Finally I can check my prototypes about hot spots and heat spreading. A resolution of 80x60 was nothing to write home about, but 320x240 for 1200 Euro (incl. VAT) is fair.... and as I side effect I can check my house for hidden problems.
« Reply #145 on: October 24, 2013, 11:28:29 pm »
Just tried a few permutations of sleep mode to see if test mode can be sustained longer term, but it seems to flake out - if plugged int USB it sticks at the battery logo when you wake, if not, it sort of wakes up then crashes.
I suspect cockup over conspiracy on this one....
Of course until we find the secret key or fully hack it, a little PIC/AVR on a flex plugged into the test connector to say "usbfn RNDIS" when it sees the command prompt would do the trick...!
« Reply #146 on: October 24, 2013, 11:34:00 pm »
Little snippet from resources when in service mode
.caps.config: (3)
name            "app E4 1.0 + app prodconvconf_std 999.9KaKaOnly"
« Reply #147 on: October 24, 2013, 11:44:48 pm »
Update - although manually turning off from service mode crashes it, it seems like if you let the auto-power off time out, it wakes back up in service mode (with  RNDIS still running).
Incidentally I think the image resolution is being limited to some extent by the lens. Hard to tell if the temperature data is still accurate.
Question for any TIC experts - would a bigger lens affect the calibration? (looks like you probably could recal via service mode though)
oh and for the web experts - by looking through the .asp files etc. can you deduce anything about what it actually does when you hit the 'enable service mode' button? Even a snippet of text that could be looked for in executables might be interesting. I have seen references to something like "oneshotservicemode"
« Last Edit: October 24, 2013, 11:47:47 pm by mikeselectricstuff »
Offline ixfd64
    • Facebook
« Reply #148 on: October 25, 2013, 12:05:34 am »
I'm not sure if this helps, but I found these links to be quite interesting:
http://www.imc-store.com.au/v/vspfiles/assets/images/flir%20a310%20technical%20notes.pdf
http://support.flir.com/DocDownload/Assets/75/English/T559504$A.pdf (copy and paste the URL if it doesn't work)
« Reply #149 on: October 25, 2013, 12:12:22 am »
Your second hyperlink is broken -- copying the URL and pasting it in works, however.
I think that's the same doc I linked to previously
