Hi i am new to this topic and will be the owner of a Flir E4 v1.21 ( hw 1.1L ) soon. for my model i found the howto and the files like TOOLS1.zip and ADDMENU-BETA3.zip but i am curious after a succesfull upgrade on what level i will be..... is it 2.30(E8) , i am completel lost there...
i read a lot of info on this topic and understand there are many different versions which can be upgraded.
but is there a real upgrade path which can be followed for everybody to understand.. i will make a small excel tabel for what i discovered until now.
my opinion is that i am wrong with my conclusion but help/advise wanted.
people like me have or bought a Flir E4 from a specific version and where can we jump into the upgrade path?
do i understand right if all E4 model (v1.xx ) after they are upgraded they are on version V2.30(E8) (yellow) or compatible with v2.30(E8) ?
and from there on can be upgrade by Flir GUI sofware to v2.8 or ...? or is this even a misunderstanding?
if not can someone explain to me and others on this forum new on this topic, on how these upgrade path work to fully understand what to do and which way to go or not no go..
because we all don t want to brick our units by going the wrong path..
because i also read post from version downgrades, then i am totally lost...., why should that be done?
you see many questions but who can clear them up for us newby's
after reading over and over again.. many page of this topic.. i think it is a bit more clear for me:
first you change your E4 into a E8 with the RESOLUTION HACK and the MENUADD and afterwards you run the firmware upgrade?? to the latest ..2.8 or.?
is that how it works?
or from what i saw later first upgrade your device to 2.3.0 and then do the hacks.. ?
who can jump in and let me know what the best choice is.
What FW version to stay/upgrade/downgrade to and then do the resolution and menu hack?
