Poll
274 (27.9%)
444 (45.3%)
49 (5%)
50 (5.1%)
164 (16.7%)
Total Members Voted: 803
Author Topic: Flir E4 Thermal imaging camera teardown  (Read 3787531 times)
Offline Maxpax
« Reply #7350 on: October 14, 2015, 01:20:39 pm »
 :-DD
That's on me :)
Offline tomas123
« Reply #7351 on: October 14, 2015, 04:31:11 pm »
Ok, I managed to extract all info from putty by copy to clipboard in sections and puzzle it together. Phew!
bad news, your sensor is only 80x80
i5
.image.flow.framebuffer.geom:
r---r--------- 0 root   root   <i> bitsPerPixel                  16
r---r--------- 0 root   root   <i> height                        80
r---r--------- 0 root   root   <i> width                         80
.calib.detector.geom:
rw--rw-------p*0 root   root   <i> imgPixX                       80
rw--rw-------p*0 root   root   <i> imgPixY                       80
compare the values with an unpatched Flir E40
image 160x120 <-> sensor 320x240
E40
.image.flow.framebuffer.geom: (3)
r---r--------- 0 root   root   <i> height                       120
r---r--------- 0 root   root   <i> width                        160
.calib.detector.geom: (8)
rw--rw-------p*0 root   root   <i> imgPixX                      320
rw--rw-------p*0 root   root   <i> imgPixY                      240
we need 17 posts to check it  :(
« Last Edit: October 14, 2015, 04:33:59 pm by tomas123 »
Offline Maxpax
« Reply #7352 on: October 14, 2015, 04:35:39 pm »
Okay. If you are 100% sure, then - I'll live with that.
Thank you so much for your help and time spent on this.
Offline Maxpax
« Reply #7353 on: October 14, 2015, 05:17:01 pm »
But hey, what's up with this section then:
.caps.config.image.settings:
r---r--------- 0 root   root   <b> enabled                     true
r---r--------- 0 root   root   <i> resIR                        120
Offline encryptededdy
« Reply #7354 on: October 14, 2015, 07:09:37 pm »
i5
E40
That's so odd...
I'm pretty sure they don't make a 80x80 sensor. The lowest res non-lepton sensor is a 80x64 50 micron sensor that you find in the FLIR A5.
Unless they're using the ULIS Pico80P, but that's very unlikely.
Offline tomas123
« Reply #7355 on: October 14, 2015, 07:58:46 pm »
ok, you don't give up.
The next proof is your calibration file. The calibration with bad pixel mapping is taken by full resolution.
your calibration file name is ds250C_we_ap_fi_le.gan
.registry.calib.detector.deadPixMap.ds250C_we_ap_fi_le:
rw-dr--------- 0 root   root   <a> fileName        "ds250C_we_ap_fi_le.gan"
rw-dr--------- 0 root   root   <i> type                         100
you find it here
+---FlashFS
|   +---system
|   |   +---maps
|   |   |       ds250C_we_ap_fi_le.gan
you can read the gain map with exiftool
here a sample from a E40
$ exiftool ds250C_we_ap_fi_le_static.gan
File Type                       : FLIR
File Type Extension             : fff
Gain Dead Map Image Width       : 320
Gain Dead Map Image Height      : 240
Gain Dead Map Image Type        : TIFF
Gain Dead Map Image             : (Binary data 153804 bytes, use -b option to extract)
 8)
« Last Edit: October 14, 2015, 08:03:14 pm by tomas123 »
Offline Maxpax
« Reply #7356 on: October 14, 2015, 08:28:53 pm »
Ok.
exiftool output for ds250C_we_ap_fi_le.gan:
ExifTool Version Number         : 10.02
File Name                       : ds250C_we_ap_fi_le.gan
Directory                       : .
File Size                       : 13 kB
File Modification Date/Time     : 2000:01:01 00:34:00+01:00
File Access Date/Time           : 2015:10:14 12:44:10+02:00
File Creation Date/Time         : 2015:10:14 12:44:10+02:00
File Permissions                : rw-rw-rw-
File Type                       : FLIR
MIME Type                       : application/unknown
Creator Software                :
but there's another file in the maps directory called "ds250C_we.crs" mentioned, among other places, here in the allsettings-file:
.registry.calib.detector.data:
rw-dr--------- 0 root   root   <x> ds250C_we
with the exiftool output:
File Name                       : ds250C_we.crs
Directory                       : .
File Size                       : 13 kB
File Modification Date/Time     : 2000:01:01 00:29:00+01:00
File Access Date/Time           : 2015:10:14 12:44:09+02:00
File Creation Date/Time         : 2015:10:14 12:44:09+02:00
File Type                       : FLIR
Creator Software                :
Coarse Map Image Width          : 80
Coarse Map Image Height         : 80
Coarse Map Image Type           : TIFF
Coarse Map Image                : (Binary data 13004 bytes, use -b option to extract)
That kind of convice me that you are right, tomas123. But I just can't help to wonder why the resolution 120x120 is suggested here and there in filenames and the allsettings-file. Could it be that the sensor has different "modes"? ...But I'm not the one to speculate on this, all you other people here have way more knowledge about how it's normally done...
« Last Edit: October 14, 2015, 08:32:28 pm by Maxpax »
Offline tomas123
« Reply #7357 on: October 14, 2015, 08:51:15 pm »
 the fw is the same for all ix cameras (all resolutions)
« Last Edit: October 14, 2015, 11:00:45 pm by tomas123 »
Offline stefbeer
« Reply #7358 on: October 14, 2015, 08:54:36 pm »
@ Maxpax:
Back then I successfully upgraded my i3 (bought about 3 years ago) with the instructions from this post. When I look at your original config file, then all the lines essential for the hack are missing. Which means that you have a later hardware revision and / or firmware version. And please note the last line of the linked post. My TIC was able to do the full 144 but it seems yours really only can do 80.
And the 120 you mentioned here are from the config file you copied from the pdf with the instructions. Because the "new" config file is successfully loaded (which means you did all the # ID and # CRC01 stuff correctly :) ) this parameter is set but sadly because of the hardware / firmware this parameter doesn't do anything. :( And even if it did, you really seem to have only a 80 sensor.
And the timestamp from January 1st 2000 is just a default time if the actual time isn't set, this doesn't mean the TIC is 15 years old. :)
I have no idea why the i-Series has three different types of sensors but it seems that you just have the wrong one. :(
« Last Edit: October 14, 2015, 08:57:36 pm by stefbeer »
Offline joe-c
    • Joe-c.de
« Reply #7359 on: October 14, 2015, 09:52:42 pm »
Hello,
try to go to: FlashFS\system\maps\  there should be a *.gan file
ds150C_we_ap_fi_le_static.gan (from FlirC2)
ds250C_we_ap_fi_le.gan (from Flir i3... later enhanced to 120x120)
ds250C_we_ap_fi_le_static.gan (from Flir E4... later enhanced to 320x240)
I guess... this Calibration file was ever in the full resolution of the Camera.
Try to decode it with my Dev Tools file to image decoder:
http://joe-c.de/pages/posts/programm_dev_tools_133.php#bilder
from the i3 and E4 i get a 320x240 resolution, the C2 brings only 80x60... it has a Lepton core.
Freeware Thermal Analysis Software: ThermoVision_Joe-C
Some Thermal cameras: Kameras
Offline tomas123
« Reply #7360 on: October 14, 2015, 11:04:29 pm »
@ Maxpax:
You wrote that exiftool can't read your
Please zip and upload your gan file. I will check it.
Offline Maxpax
« Reply #7361 on: October 14, 2015, 11:31:08 pm »
vielen dank!
Offline tomas123
« Reply #7362 on: October 15, 2015, 07:00:34 am »
just for fun some exiftoool and imagemagick magics.
your ds250C_we_ap_fi_le.gan has the Flir Tag FFF_TAGID_DeadMap = 4 (see pdf)
with the config.txt file from attachment we can extract the RAW 80x80 image
>exiftool -config config.txt ds250C_we_ap_fi_le.gan
ExifTool Version Number         : 9.91
File Size                       : 13 kB
File Type                       : FLIR
Creator Software                :
Embedded Image Width            : 80
Embedded Image Height           : 80
Dead Map                        : (Binary data 12800 bytes, use -b option to extract)
>exiftool -config config.txt -b -DeadMap ds250C_we_ap_fi_le.gan > 1.hex
now convert with IM
>convert -depth 16 -endian lsb -size 80x80 gray:1.hex  t2.png
resize for better bad pixel peeping
« Last Edit: October 15, 2015, 09:34:45 am by tomas123 »
« Reply #7363 on: October 15, 2015, 07:37:05 am »
Still no idea where FLIR is getting these 80x80 sensors.
Perhaps in the later versions some image processing (specifically downscaling) got moved on chip?
But that would make no sense because the E4 doesn't do that...
hmm...
Offline Maxpax
« Reply #7364 on: October 15, 2015, 10:09:28 am »
My i5 is blue and gray, not black. I think it is one of the earlier versions of i5, and therefore one of the older designs. I suppose it is quite natural to change designs i the beginning of new models as a company gains in understanding from testing, customer feedback, ideas on how to achieve cheaper/simpler manufacturing and not least, providers who approach the company with deals on technology parts, such as sensors.
Anybody want to buy it?  ;D
« Last Edit: October 15, 2015, 12:41:16 pm by Maxpax »
Offline tomas123
« Reply #7365 on: October 17, 2015, 06:13:52 pm »
sorry for double posting
I published in the seek thread an excel sheet to show, why the RAW values of an E4 microbolometer (response of "A/D Counts") are linear to radiance [W / m^2] (per nm wave length) and not linear to temperature [Kelvin]. The difference is not great.
https://www.eevblog.com/forum/testgear/yet-another-cheap-thermal-imager-incoming/msg779709/#msg779709
« Last Edit: October 17, 2015, 09:34:59 pm by tomas123 »
Offline brobbuilder
  • Country: as
« Reply #7366 on: October 18, 2015, 04:52:15 am »
Would be cool to get a firmware on the i-series that dumps full rez (320x230) to SD, since the screen can't handle more than 140x140.
We never did figure out the pinouts on those, did we?  If we did, the hazard cams from BMWs/Audis might finally be reusable, since they use the same sensor.
Offline jumbo
« Reply #7367 on: October 28, 2015, 08:43:45 am »
Hello,
I changed E30bx to E60bx and its really clear view now, thanks eevblog  :clap:
but is it possible to change settings in video mode to turn of staff on right?
If you don't understand me I attached picture below.
On first its all staff (temperatures, point etc.) on second its what I would like to have on video mode.
I would like to clear screen only on video mode - not on picture mode.
Offline Chanc3
« Reply #7368 on: October 28, 2015, 11:44:21 am »
Hello,
You can turn it all off in one of the settings panels - I'll have to dig out my E60 and see if I can find it.
Offline jumbo
« Reply #7369 on: October 28, 2015, 08:44:49 pm »
Hello,
From menu I can only switch off left site
« Last Edit: October 29, 2015, 05:45:16 am by jumbo »
Offline tomas123
« Reply #7370 on: October 29, 2015, 07:48:20 am »
With telnet you can use commands like
rset ui.userSettings.overlayLogo false
It's a sample from my Flir Exx old version without MSX
For more informations google this string on eevblog
« Last Edit: October 29, 2015, 07:52:59 am by tomas123 »
Offline Chanc3
« Reply #7371 on: October 30, 2015, 11:49:37 am »
Or you can delete the logo.bmp file! (Make sure you have a backup).
Good news for those with an i50 - I have successfully upgraded the GUI to include better measurement functionality and I have also updated the IR resolution to 240x240! (up from 140x140). Funnily enough, the i60 only goes up to 180x180 I think.
Does anyone have an InfraCAM SD? I picked one up dead cheap the other day but it doesn't get past the boot screen (doesn't even show it loading up). I've tried connecting to it and pulling off the files so I can inspect them, but FTP only seems to work very briefly - any ideas?
Offline simclardy1
« Reply #7372 on: November 03, 2015, 02:48:23 am »
 :scared: celebrate! not scared.
I managed to get the resolution resolved. I managed to get the menus updated. Problem. the picture in picture and thermal fusion are on the menu but I can't operate them? the other thing is Bluetooth and wifi don't seem to do anything? I don't care too much about this but the fusion or pip would be a plus. The succeeded to activate: camera record, resolution, dots, delta, isotherm, zoom.....wow it's really cool.
Thanks to mike, and everyone!
Offline simclardy1
« Reply #7373 on: November 03, 2015, 03:42:33 am »
I got it! I had to edit the appcor config file a bit more. I made a mistake on the framegrab entries.
cheers! if I can help a newbie like me let me know.  ;D
Offline lefedor
  • Country: ru
« Reply #7374 on: November 03, 2015, 05:35:03 pm »
Hi, I'm new in this topic, need scope owner help with my thermal sensor (have sensor (flir photon camera) with dead electronics):
Is here exists any fella with oscilloscope (with logic analyzer may be, but i guess it's not critical) and also brave, enthusiastic and open to make few start up/initialization measurements on his sensor pins?
Looking for both owners of 'I' series and 'E' series.
