Author Topic: FLIR E4 Wifi Resolution and Menu Hack Thread  (Read 476890 times)
Offline xrazzed
Re: FLIR E4 Wifi Resolution and Menu Hack Thread
« Reply #1325 on: July 19, 2024, 07:19:19 pm »
If i use that .fif file the problem is it can not connect to camera smh
log: Connection timeout
Operation aborted
Close TELNET link
NoAdapter
Offline Bud
« Reply #1326 on: July 19, 2024, 07:35:11 pm »
What version of Windows are you running?
run the Windows command line and enter this command:
route add 169.254.44.19 mask 255.255.255.0 169.254.44.18
then from same command line ping the camera and see if it responds. If it responds, run the .fif again.
ping 169.254.44.18
Offline xrazzed
« Reply #1327 on: July 19, 2024, 07:37:35 pm »
ping 169.254.44.18
translation :
Microsoft Windows [Version 10.0.19045.3208]
(c) Microsoft Corporation. All rights reserved.
C:Windowssystem32>route add 169.254.44.19 mask 255.255.255.0 169.254.44.18
Add route failed: The parameter was set incorrectly.
C:Windowssystem32>
Edit:  i did the Ping thing camera answered.
translation:
Exchange of packets from 169.254.44.18 to 32 bytes of data:
Response 169.254.44.18: Bytes=32 Time<1ms TTL=128
Ping Statistics for 169.254.44.18:
    Packets: Sent = 4, Received = 4, Lost = 0
    (0% loss)
Approximate round-trip time in ms:
    Minimum = 0 ms, Maximum = 0 ms, Average = 0 ms
« Last Edit: July 19, 2024, 07:40:15 pm by xrazzed »
Offline Bud
« Reply #1328 on: July 19, 2024, 07:43:48 pm »
Do you get anything when you click "Check Installation" or "Get Version" buttons in FlirInstallNet ?
Offline xrazzed
« Reply #1329 on: July 19, 2024, 07:45:39 pm »
The same answer for both Connection timed out. Why is FlirInstallNet sees another ip like in the end its not 18 its 19? maybe thats the problem?
Offline Bud
« Reply #1330 on: July 19, 2024, 07:49:54 pm »
Because Windows 8 and 10 do not work properly with the Flir Tools.
Try using Filezilla (as in FUBAR's procedure) to connect to 169.254.44.19
If connects, make a backup as in FUBAR procedure, then navigate to flashfs/system/appcore.d/factory.d/  and delete the file  zrndis.rsc
disconnect and reboot the camera.
Offline xrazzed
« Reply #1331 on: July 19, 2024, 07:52:46 pm »
here is another problem.
translation:
Status: Connecting with 169.254.44.19:21...
Error: Connection dropped after 20 seconds of inactivity
Error: Unable to connect to the server
Status: Waiting for a rerun...
Status: Disconnected from the server
edit 2:
Status: Connecting with 169.254.44.18:21...
Status: Failed to establish a connection with "ECONNREFUSED - Connection rejected by the server".
Status
« Last Edit: July 19, 2024, 07:55:41 pm by xrazzed »
Offline Bud
« Reply #1332 on: July 19, 2024, 08:00:21 pm »
OK you need to go to the last resort which is getting a computer or a Virtual Machine with Windows XP.
Install the Flir Drivers and Flir Tools on Windows XP, then check if the IP address is now 192.168.0.2 - you should see a popup in the right bottom corner of Windows taskbar as you plug the camera in. Or you can use ipconfig. Then run the .fif
Offline xrazzed
« Reply #1333 on: July 19, 2024, 08:02:18 pm »
Okay got it, is Virtual box ok to use as virtul machine?
Offline Bud
« Reply #1334 on: July 19, 2024, 08:18:29 pm »
Yes it works fine for this purpose.
Offline xrazzed
« Reply #1335 on: July 19, 2024, 08:24:49 pm »
Im sorry i have some troubles with this app maybe u can tip me another one pls? windows xp doesnt start bcs of some problems idk
Offline Bud
« Reply #1336 on: July 19, 2024, 08:28:39 pm »
I am unfamiliar with other VM platforms. You can download one of older versions. I am using VirtualBox v6.1, it runs XP just fine.
Offline xrazzed
« Reply #1337 on: July 19, 2024, 08:36:03 pm »
okay okay as u say i downloaded same version. but still i have problem
Offline xrazzed
« Reply #1338 on: July 19, 2024, 08:55:23 pm »
This flir e6 belongs to my father, so he wanted to say thank you for your help! currently im downloading Windows XP iso to somehow boot this virtual machine, am i doing right things?
Offline Bud
« Reply #1339 on: July 19, 2024, 09:05:00 pm »
There are more knowledgeable people than me who should be able to help, as I Have not installed anything for a long time. I recommend you open a new topic perhaps in the Computers section of the forum and ask for help to guide you through setting up a WindowsXP VM and walk you through how to redirect USB ports to it.
Offline xrazzed
« Reply #1340 on: July 19, 2024, 09:30:53 pm »
Please help me go through it :) almost done with iso.
Edit : I DID IT finally
« Last Edit: July 19, 2024, 09:59:05 pm by xrazzed »
Offline xrazzed
« Reply #1341 on: July 19, 2024, 10:09:21 pm »
How do i download all of this?
Offline Bud
« Reply #1342 on: July 20, 2024, 12:30:42 am »
Please keep this thread clean from general computing questions. Use the Computers board of EEVBlog for that and Google search. Imagine someone in trouble like you comes to this thread for information on thermal cameras and all that person will see is your 200 questions on how to install Windows XP.
You are welcome to come back here once you have set up your VM and other software.
Offline Marekx89
  • Country: sk
« Reply #1343 on: Yesterday at 05:55:37 pm »
Hello, is possible copy directory flashBFS, flashFS and flashIFS from one E6 to another E6 ?
Offline Bud
« Reply #1344 on: Yesterday at 10:45:14 pm »
This thread is for E4. If you do not get any answers that means noone knows.
