Author Topic: (Solved) FLIR i3 (Early version) Charger spec please  (Read 3199 times)
Offline FraserTopic starter
« on: February 15, 2017, 05:59:28 pm »
Hi all,
I have just purchased a FLIR i5 that comes without its charger.
Please will a FLIR i series camera owner let me know the voltage and current rating on their charger. Plug polarity would also be great.
Many Thanks
Fraser
Correction made... I listed it as an i3 when it is in fact an i5
« Last Edit: February 20, 2017, 02:43:58 am by Fraser »
Re: FLIR i3 (Early version) Charger spec please
« Reply #1 on: February 15, 2017, 07:23:37 pm »
No worries, found the information myself.
Voltage: 5V
Current capability: 2A
Barrel connector polarity : Centre +
Fraser
Offline firehopper
« Reply #2 on: February 15, 2017, 09:07:12 pm »
lol added another one to your collection huh? I managed to get myself a flir one for android now :)
« Reply #3 on: February 15, 2017, 09:42:25 pm »
@firehopper,
Yep, I did not have an i Series camera  ;D
I am also awaiting delivery of a very nice thermoelectrically cooled Agema 510 this week. It is a Shortwave camera that uses a Lead Selenide detector array. Very different to modern microbolometer cameras.
Fraser
Offline sam1275
« Reply #4 on: February 16, 2017, 02:28:13 pm »
Hi Fraser,
Would you please take a look at your i3's internal file, and tell me if you have a 120 or 140 fpga bin?
The detailed reason is explained in the "update5" section of the following post:
https://www.eevblog.com/forum/thermal-imaging/please-anyone-help-me-hacking-my-flir-i5/
Also you may find that post useful if you want to hack the most out of your i3  ;)
Cheers,
Sam
« Reply #5 on: February 16, 2017, 02:44:03 pm »
Hi Sam,
I like your work on the i5 👍🙂
Mine is a MK1 i5 120x120
Fraser
Offline sam1275
« Reply #6 on: February 16, 2017, 06:35:37 pm »
Thank you Fraser,
I think you mean yours is a Mk1 i3?
Mine looks like a Mk2 from outside, but it still only have 120*120 instead of 140*140, I don't know why.
So if any of us can get a 140 bin file from a Mk2 camera somewhere, we may be able to get 140*140 on both of our cameras.
Good luck to us and hope that day will come earlier :P
Sam
« Reply #7 on: February 16, 2017, 06:56:59 pm »
Hi Sam,
No mine is a Mk1 i5 that I will upgrade to 120x120, or higher if possible.
The case is the original grey and blue with i5 shown above the LCD screen and Lens surround
Fraser
Update. Ah I see I listed the camera as an i3 in my first post. It is definitely an i5 🙂 Not that it makes much difference as I am upgrading to i7 spec.
« Last Edit: February 16, 2017, 07:09:29 pm by Fraser »
