** EDIT **
Worked it out. See later post
Does anyone know how to get presets and extra palettes working?
Re Presets,
I have enabled the menu item (see photo) but it is not populated with choices. I have a folder of presets from a later model and have tried putting this folder in all possible folders/subfolders to see if the unit recognises it, but with no luck. I have tried with a different number of presets in the folder and renaming the folder. I've also tried putting the preset files in various folders, again without sucess. Anyone had better luck?
Re extra Palettes,
I found that the individual files need to be placed in the '/FlashFS/system' folder, where they will be recognised by the unit and displayed as a choice in the palette menu. (see photo)
HOWEVER Althought the Palette can be chosen and will display correctly, the name of the Palette in the menu is always prefixed by '$' and suffixed by '.pal'. Also, the menu box expands to the number of Palettes it finds, but should you add more than 3 palettes, you cannot force the display to scroll down to the 'out of sight' palettes at the bottom of the list (or to the 'Invert palette' option). I think that maybe there is a programatic limit on palettes?
Any help will be gratefully received. I believe the various Ex series hack(s) involve files not present on the Exx series.
**EDIT**
I'm on an old software: 1.24.16, so without any good suggestions, I'm thinking of upgrading to 2.27.16 (The latest for MK1s) which will hopefully offer more functionality. That software is reported not to affect any user changes to files.
https://www.eevblog.com/forum/thermal-imaging/flir-e60-to-e60/msg3946942/#msg3946942
