Author Topic: Flir i60 Firmware Update  (Read 4076 times)
Offline robert_
« on: January 29, 2016, 05:49:02 pm »
im trying to update the firmware on an old i60 with V1.21 installed, as it does have a lot of annoying bugs (ie camera hangs when trying to save an image with "Area Maximum" measurement active) and i hope there will be some improvements (and some refreshing, new bugs instead of the year-old ones i have now).
I tried V 2.19.1 (which fails with a checksum error), according to Flir FAQ im supposed to install 2.17.1 first, which also fails, this time with the attached message. I did triple-check the integrity of the file on the SD card, which is okay.
Any ideas?
Flir told us that camera is "long out of support" and we should buy a new one. Actually thats the same they told us when we wanted new battery packs, so i had to make them myself already.
« Last Edit: February 01, 2016, 04:43:58 pm by robert_ »
Offline Chanc3
Re: Flir i60 Firmware Update
« Reply #1 on: February 02, 2016, 01:54:16 pm »
Are there any other versions of the firmware available? Perhaps try that first?
Failing that, I have a backup of the files from my i50 which I upgraded to an i60, so they may be of use. I cannot remember what version of firmware it was however.
Offline robert_
« Reply #2 on: February 03, 2016, 06:39:24 pm »
Couldnt find much related to the ixx series, at least no other fw version anywhere.
It would be good if there was some kind of changelog to see if it would actually fix some of the bugs i have...
I dont know why some companies known for really expensive products like Flir ot Tek have so bad customer support. They could afford it for sure.
Offline Chanc3
« Reply #3 on: February 08, 2016, 01:09:26 pm »
Hello
I've located my full backup I made of my old i50. You can download it all here: https://www.dropbox.com/s/3rkqn68ntigub7r/FLIR%20i50.zip?dl=0
Perhaps replacing some of the files may help stabilise the camera, but please be aware this could brick your camera and that I cannot be held responsible!
Offline Chanc3
« Reply #4 on: March 04, 2016, 04:19:38 pm »
Any ideas?
Any luck?
Offline robert_
« Reply #5 on: March 08, 2016, 06:02:58 pm »
Not really.
Im trying not to brick it yet...
Also i start to have some doubts wether any firmware upgrade from FLIR ever fixed any bug. It only ever seems to introduce new ones...
