Here is the teardown of a FLIR Micron A10 core. It's more or less the same what can be seen in the already posted teardown but in pictures
An interesting tear-down video of an OMEGA core that was being used in a CCTV camera housing.
https://www.youtube.com/watch?time_continue=3&v=D0OlWmr5R10
Unfortunately the core does not work
Current consumption seems OK (~185mA @ 5V) but there is no FFC event and the video out has 3,2V DC instead of the RS-170 video signal.
RS-232 lines stay at 0V but this seems to be the auto shutdown feature of the MAX3221.
Voltage regulators seem to work, on the power board there are 5 switch mode regulators:
LT1308A (SEPIC converter, 6,43V out)
2x LTC1877 (marking LTLU, buck converter, 1,50V and 1,78V out)
LT1613 (marking LTED, boost converter, 1,78V in, 3,38V out)
LT1617 (marking LTKA, inverting converter, -17,5V out)
Nothing gets unusually warm or hot, the DSP and the LT1498 (OPA on the ADC board) get a bit warm and the FPGA stays cool.
Interesting thing is the photoelectric sensor (IR LED + phototransistor in one "black" 4-pin package on the connector board in the corner near the green bodge wire). With a NIR-Cam it can be seen lighting up and it seems like the current consumption is a bit higher when there is no reflector while the power is supplied (202...198mA @ 5V without reflector, 192...178mA with reflector).
If anyone has a hint what could be wrong, let me know
Unfortunately there is another report of a dead A10:
I operate an exploration, research and recovery group and have used an A-10 Micro since 2007. and just a few weeks ago ours failed.
I'd try to get a serial connection, does anyone have a copy of the software mentioned here?
OK, I have found the Indigo Omega/A10 GUI for you.
It is at the bottom of this support page.......
http://www.flir.tw/cores/display/?id=53130
Maybe some settings are wrong but I doubt the imager can be completely halted by software.
regards
Cat
