Things just got interesting
I reassembled the PS32 PCB, Battery, TAU interface and TAU core.
Result: The scope booted, raised an alarm and shut down
I had a little suspicion about the model of TAU that had been in the PS32 so fitted my MS224 TAU 1 interface PCB.
Result: The scope booted and displayed the TAU image perfectly..... BUT, the scope does light its error LED and no push button functions work.
Hmmmm, interesting.
I carefully observed the image being produced in the EVF. It looked clearer than I remembered on the MS224 EVF. This was more evidence of what I already suspected.
A quick check on the fitted KOPIN LCD driver IC confirmed my suspicions. It is an A910 instead of the A210 fitted in the MS224/PS24. The difference is simple. The A910 is 640x480 VGA and the A210 fitted in the MS224 is 320 x 240 QVGA
My PS32 donor is in fact a SCOUT II that is normally fitted with a TAU 2, hence the issues when using a TAU 1 on it, and it upscaled to 640 x 480 resolution for a better EVF image.
Well I am chuffed to have a SCOUT II but now I need to see if it is possible to convince it to work with a TAU 1. Theer are obviously differences between the TAU 1 and TAU 2 interface boards. Maybe the pinouts are different at the TAU connector ? I will have to check. I am hoping that teh TAU is just not receiving its RS232 commands due to a pinout issue.
It would be great to be able to use the SCOUT II PCB due to the better EVF image and the added functionality of a composite video output capability via the USB port. This video out feature became available on the PS32R and SCOUT II PS32 so I suspect that I actually have a PS32R and that, though not stated by FLIR, it is a SCOUT II masquerading as a late model SCOUT I. All interesting stuff
To clarify:
Standard SCOUT I PS32320 x 240 pixel QVGA EVF
TAU 1 320 x 240 pixels
Video output via contacts on bottom of case
SCOUT I PS32R - Camouflage colour scheme and long range lens fitted640 x 480 VGA EVF
TAU 2 320 x 240 pixels
Video output via USB socket
SCOUT II PS32640 x 480 VGA EVF
There are also the SCOUT I LS32 and LS64 scopes but those are always found in black cases.
My hypothesis would also explain the completely different PCB used in PS32 donor.
Sadly i must get on with other chores so more when I have time.
Fraser
